Clutch Cable Broke AGAIN!!!!!! - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 8 (permalink) Old 04-04-2012, 10:09 AM Thread Starter
I repalced my clutch cable last fall. I have ridden less than a 1000 miles and it broke again. Does anyone know why this may be happening? Does anyone know of a decent replacement other than going to the dealer?
Thanhs
69fasbak is offline
post #2 of 8 (permalink) Old 04-04-2012, 12:03 PM
whoaru99's Avatar
The cables that broke have been OEM cables or aftermarket cables, I presume at least the first one was OEM but what about the others?
They're getting frayed, or?
whoaru99 is offline
post #3 of 8 (permalink) Old 04-04-2012, 03:08 PM
SteveJB's Avatar
Displacement/CC's: 1700 cc
Color: Candy Cardinal Red
Where is it breaking? If you know that you should be able to find the problem. The only bike I had this problem on turned out to have a worn caliper that was dragging the cable over a sharp edge. My 9er still has the original @ 25,000 miles.
SteveJB is offline
post #4 of 8 (permalink) Old 04-04-2012, 06:40 PM
Have 53,000 with my original cable with no issues other than a tighter adjustment now and then.It's rubbing on something or in a bind somewhere. Like SteveJB said,see where its breaking at and look in that area for the problem
xxxxxxRTL Rider is offline
post #5 of 8 (permalink) Old 04-04-2012, 06:54 PM Thread Starter
They both frayed at the end at the connection and both were OEM. I guess it is possible they may have been defective. I ordered a new OEM today. When I pick it up I will order an extra to keep in the saddle bag.
69fasbak is offline
post #6 of 8 (permalink) Old 04-05-2012, 06:33 AM
whoaru99's Avatar
Maybe you've gone through it all already, but if they're frayed they must be rubbing abnormally on something in the vicinity of the frayed area. Just doesn't happen for no reason and doesn't seem to be a common issue at such low amount of use. That tends to point to something on your bike, not a problem with the cable per se.
whoaru99 is offline
post #7 of 8 (permalink) Old 04-05-2012, 10:07 AM
MnV500's Avatar
I'd take a look at the screw adjusters for the cable, if that's the area where it's fraying. Sometime they can have a burr where the cable slids back and forth. Just need to file this area smooth.
-Steve
MnV500 is offline
post #8 of 8 (permalink) Old 04-05-2012, 09:47 PM
CGCWO's Avatar
you were not specific about which end of the cable is giving you problems. I snapped one on my 2010 at the connection on the right side of under the engine. The barb pretty much just snapped off, that was at approximately 6000 miles. Replaced it with an OEM replacement and haven't had a problem with the new one yet, I am at 11000 miles right now. I assumed my problem was a faulty cable.
2016 Indian Dark Horse Chief w/Distressed tan leather
2010 VN 900 Custom SE Tourer
F&S SE Back Rest w/3" extensions
Roadkrome Sturgis Hardbags
Corbin Dual Tourer
Turn Signals w/Smoke Covers
Genmar Risers
Black Mirrors
Black 09 SE Pipes Stage 2 De-baffle
Blacked-Out Handlebar Controls
2008 HD FLH Fairing w/stereo and 6in shield
CC Crash Bar Black
Passenger and driver Floor Boards (Chrome)
Pirelli 200 Rear&90/90 Front
USCG CWO (Ret)
CGCWO is offline
Has your clutch cable ever broke? Water Rat Vulcan 2000 70 02-15-2019 05:18 PM
Clutch cable broke AZPoseur Vulcan 900 5 11-27-2014 08:10 PM
Clutch cable broke Hobbes Vulcan 2000 20 11-10-2014 08:01 AM
Interesting ride home - clutch cable broke. Mambo Dave General Vulcan Talk 14 12-23-2011 07:03 AM
Clutch Cable broke cruisergeek Vulcan 800 12 06-08-2011 05:18 PM
