TPS Sensor? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 17 (permalink) Old 04-03-2012, 07:41 PM Thread Starter
TPS Sensor?
I'm not even sure if it has one, but lately my 900 Custom has randomly been sticking at a higher idle than normal and eventually will drop back down, it also occasionally when you crank back the throttle, the engine does not react immediately and when it does it hardly pulls then seems to suddenly react. It doesn't do this every time, but has a couple times here lately... Any ideas? Thanks, -Kyle
68novabbc is offline
post #2 of 17 (permalink) Old 04-03-2012, 08:17 PM
Yes the VN900 has a TPS SENSOR.
At what point does this happen, shortly after start or later during the ride.
If this happens within two minutes after the start, you might check the voltage on your battery.
If this is during a ride give the throttle cables a shot of oil, maybe sticking.
John
"I am a modern cowboy, on a steel horse I ride"
09 VN900 Classic
Big 3 +++++
Double Darkside
Bytehead is offline
post #3 of 17 (permalink) Old 04-03-2012, 10:32 PM
Banned
A Throttle Position Sensor Sensor?
flywithlloyd is offline
post #4 of 17 (permalink) Old 04-03-2012, 11:24 PM
kfolse107's Avatar
Is that related to a hose "pipe"? Or a hot water heater?
Sent from my Motorcycle iPhone app
I care more about SPG (smiles per gallon)
than MPG (miles per gallon)
2009 Vulcan 500 LTD
Scootworks Risers
Slipstreamer Enterprise windshield
Protac driver backrest
Rumble Road speaker system
River Road saddlebags
Priority Plus tail light module
Kuryakyn chrome accessory plug
Kuryakyn ISO grips (6235)with Throttle Boss
JTF512 17tooth sprocket
"Manuel/Vicente" custom engine guard
Hardley highway pegs (freebies)
kfolse107 is offline
post #5 of 17 (permalink) Old 04-04-2012, 06:39 AM
HEY, no spell check at work OK.
John
09 VN900 Classic
Big 3 +++++
Double Darkside
Bytehead is offline
post #6 of 17 (permalink) Old 04-04-2012, 07:43 AM
RBS2's Avatar
Remember to put the cover sheet on the TPS report
2009 Vulcan 900 Classic
  • Saddleman Profiler Seat
  • Memphis Shades Fats 17"
  • Memphis Shades Zipper Pouch
  • Kuryakn ISO Grips - Black
  • Cobra Speedster Short Exhaust
  • K&N Air Filter
  • River Road Throw-Overs
  • Highway Bars
  • S&$T eating grins
RBS2 is offline
post #7 of 17 (permalink) Old 04-04-2012, 08:40 AM
Banned
LOL - sorry, had to crack my funny.
post #8 of 17 (permalink) Old 04-04-2012, 09:45 AM Thread Starter
LOL and yes it seems to do it within the first few minutes of riding.
post #9 of 17 (permalink) Old 04-04-2012, 10:23 AM
Possible sub-throttle problem.
sfair is offline
post #10 of 17 (permalink) Old 04-04-2012, 10:39 AM
Happens to lots of us. Called Run away high idle. Check your voltage on the battery. There is a low voltage check, after the start, that increases the rpm when low voltage is indicated. Rpm can go up as high as 2500 rpms. Really embarassing when it happens at a gas station. RMP will drop when voltage is improved or 2 minutes passes.
Started on mine in Feb, Checked my battery and it has been replaced. Issue solved.
John
09 VN900 Classic
Big 3 +++++
Double Darkside
Bytehead is offline
Bad TPS "Only part of entire Throttle Body ??? tonyernst13 Vulcan 1600 8 01-25-2016 09:19 PM
Ride On TPS Scott_in_TX General Vulcan Talk 26 02-20-2014 12:34 PM
tps question again rob56 Vulcan 1500 3 06-26-2013 04:59 PM
where can i get a tps from?? gredget Engine Work 2 05-11-2013 05:23 PM
Vulcan 1500 FI throttle position sensor (TPS) Fastrax Vulcan 1500 3 09-27-2010 02:29 PM
