Pirelli MT66!!! - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 15 (permalink) Old 03-27-2012, 01:19 PM Thread Starter
bigboy138's Avatar
Pirelli MT66!!!
This is unpaid endorsement...I just put a new MT66 up front(back tire last season) both are stock size(dont care about the speedo) and the front tire has made a huge difference in handleing for me...maybe this my imagination but it seems to inproved my cornering and it is much less "graby" on uneven pavemet and milled road surface...so in closing if your in the market for new tires check them out.
2011 Vulcan Vaquero with V&H slash cut slip-ons K&N filter driving lights and passenger back rest.
2007 900 Classic LT S&S air kit,Roadhouse Classic 2-1 serrated,PC III (traded)
"There is nothing more exhilarating than to be shot at without result." Winston Churchill
bigboy138 is offline
post #2 of 15 (permalink) Old 03-27-2012, 01:25 PM
Dan66's Avatar
I also have the MT66 and only have positive things to say. Nice tires.
Dan66 is offline
post #3 of 15 (permalink) Old 03-27-2012, 01:48 PM
Nacho's Avatar
I'm really enjoying my new MT66 on the rear. It handles much better than the Dunlop on wet roads and it is a lot less likely to lock up during heavy braking.
Nacho is offline
post #4 of 15 (permalink) Old 03-27-2012, 02:21 PM
Next time you need a front tire, give a thought to the MT66 Rear in 130/70/16 for the front. Turn the tire to run in reverse, and enjoy.
Reason. Rear tires are made with almost 2x the rubber the front has, more wear is put on the rear tire, than the front, so the rear is thicker in the hope they will wear out together.
Double your milage with the same handling as a front tire.
6,000 miles and hardley worn at all.
John
"I am a modern cowboy, on a steel horse I ride"
09 VN900 Classic
Big 3 +++++
Double Darkside
Bytehead is offline
post #5 of 15 (permalink) Old 03-27-2012, 03:06 PM
Why run it in reverse? This would seem to inhibit the tread from evacuating water correctly. Isn't the front a 130/90-16 on the Classic/LT?
2006 VN900 Classic LT - Red and Black
Stage III Stock Pipes - K&N Filter in Stock Box - Amsoil - 170/80 Kenda Kruz - Saddlemen Explorer - Willie & Max Windshield Bag - Mutazu Passenger Floor Boards - Shorai Heavy Duty Battery - Kawasaki Lowers - Black Universal Trunk mounted on Mutazu Rack - Osram 70/65w Plus 50
King43 is offline
post #6 of 15 (permalink) Old 03-27-2012, 03:31 PM
You could be right on the 90 getting old.
If you run it in reverse, you face the tread in the correct position, and you avoid the peel that could happen under extreme stress.
The tread on the front and rear tires are just reversed. If you reverse a rear you have a front.
Lots of people do it. Its the Double part of DOUBLE DARKSIDE.
The great thing is we can do it. Our front tire is the size of a lot of rear tires.
John
09 VN900 Classic
Big 3 +++++
Double Darkside
Bytehead is offline
post #7 of 15 (permalink) Old 03-27-2012, 04:18 PM
On the Kenda site for the Kruz, there is a listing for the 130/90-16 front and rear. The front has a tread depth of 4 mm and the rear a tread depth of 7.5 mm. Interestingly enough, the weight difference between the two tires is almost 10 pounds. http://www.kendausa.com/en/home/moto...reet/kruz.aspx
King43 is offline
post #8 of 15 (permalink) Old 03-27-2012, 09:36 PM
Pirelli, Metzeler, Avon, most of the tire company's make that size, it is widely used on many older bikes.
We just have the option of putting it on the front.
Well that's almost 2x.
That's OK I just shed 10 lbs of ugly lead, thanks to my new friend, and gained 10 lbs of tread.
6k and still more tread than the Dunlop when it was new. I look to get from 15k to 18k on the (rear) front. It is a motorcycle tire at LEAST, the rear tire is another story, but I expect to get 25k on the rear tire.
Do some math and it becomes very easy to see, that this is a popular mod on large cruisers that pack on a lot of miles.
Some light reading on the subject is
http://forums.delphiforums.com/n/mai...Siding%2Fstart
Ride safe.
John
09 VN900 Classic
Big 3 +++++
Double Darkside
Bytehead is offline
post #9 of 15 (permalink) Old 03-28-2012, 06:40 PM
I switched to Pirelli's last year and love'm! I currently have 8,600 miles on them and by looking at the tread should get at least 4-5,000 more out of the rear. I contacted Pirelli about tire pressures,and they replied that they always recommend higher pressures for longer lasting tires.I know some like the lower pressures for handling,but I mainly ride one up and keep 40 psi in the back and 38 psi in the front with these.I used to run lower pressures on the Bridgestones I had,but these pressures seem to work well with handling and treadwear. www.americanmototire.com seems to have the best prices I could find with free ship
xxxxxxRTL Rider is offline
post #10 of 15 (permalink) Old 03-28-2012, 09:27 PM
diehard rider's Avatar
I put front/rear Pirelli MT66 on my Classic/LT and I have 14.5k on them and still looking to get 1500+ miles from the rear. All I can say is that they are hands down much better than the crappy Dulops that I will never go back to, I love em and plan on staying with them.
2012 GREEN/BLACK VAQUERO
Kawi Quick release backrest
Kawi Passanger floorboards
Kawi Luggage rack
Klockwerks 9" windshield
Mustang Seat
Mustang pass backrest pad
Ipod adapter kit/Ipod
Black ISO Grip
Offset ISO highway pegs
PC5 W/ignition
Freedom Performance True Dual Exhaust
Altrimax HP 195/55/16 car tire.
Leather saddlebag chaps
Thunder mfg Tornado air intake
Thunder mfg Throttle Body Gasket
diehard rider is offline
MT66 in 170/80-15? Akgeezer Vulcan 900 19 12-30-2013 03:30 PM
Pirelli MT66's VulcanLife Wheels and Tires 19 12-02-2012 12:18 AM
MT66 Tire Issues BigDogGa Wheels and Tires 4 11-25-2011 06:17 AM
For those with Pirellis MT66, please help Boyaco Vulcan 900 19 09-22-2011 04:03 PM
Pirelli MT66 jevulcan08 Vulcan 900 5 07-16-2010 10:16 PM
