bigger bike in the future? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 20 (permalink) Old 03-26-2012, 07:08 AM Thread Starter
HeavyDrop's Avatar
alright so this is the battle...I bought my VN900B last year with the intention that I'd be riding mainly solo as my wife didn't seem very interested. Over the course of the season last year, I rode 2up with her several times...mainly short local runs. Lately we've been talking about taking the 9 on some of our long distance events we have planned this year, but neither one of us are lightweights and add luggage etc... We're well overweight...not to mention the fact that at 60mph plus riding solo the 9 revs out at 4k, now add the wife and luggage...well, I think we'd be near maxed out.
I see people have upgraded pullies and all that but, not sure if that'll be a long term solution.
Now as far as bigger bike options, I've looked at the Vaquero and the Road Glide so far.
Would like some input from some of you veterans.
Sent from my YP-G70 using Motorcycle.com App
05' VN1500 Classic ~ Black - Bone Stock
HeavyDrop is offline
post #2 of 20 (permalink) Old 03-26-2012, 07:47 AM
wocka, wocka, wocka
Poncho Villa's Avatar
they are called Convertibles..
hd,, yor writting in the 900 section, so the most of the discourse is going to be favorable toward making the 900 work for you. its a fine bike and a decent motor. but you are finding that its comes up a wee bit short in the power (not size) department for 2up travel w/gear. have been there and done that. its the trade off of having a EZ size handlin bike for when yor not 2up w/gear.
Iv progressed and regressed thru the years on multiple sizes and style bikes.
350,500,750,800,1000,1200,1500,1700 and now am settled with a liddle 125ci.
Iv settled for big MOTOR bikes and then strip em back to fighting weight for Tossing them around. this v2k started life at 850lbs is now a trim 650lb.. When I want to load em up for the Big Road, they already have the bones n muscle to (frame n motor) to handle all the packings can pile on.
This is not everybodys cup of tea. They want ONE bike to do EVERYTHING WELL. for that you really need 3 bikes. A full rig tourer, A day bike commuter, and a Beater Bike to get crazy on, no worries.
so find you the right size to fit yor worst case scenario,, and then strip it Nekid for yor daily fix... pix, diff ver same sled.
Poncho Villa is offline
post #3 of 20 (permalink) Old 03-26-2012, 09:14 AM Thread Starter
HeavyDrop's Avatar
Ponch,
thanks for the feedback...and love your bike. Cool what you do with her.
and...I'd say yes, the biggest issue over the road power while 2up and loaded down with luggage, Revn' out at 4-5K and not a ton of power left otherwise the bike is perfect for me and if I knew the wife would take to riding so much I would've most likely gone with the Vaquero or Nomad last year.
I've tried to get her interested in the BRC and maybe getting her a bike of her own, but I don't see that happening. She's happy as a passenger.
Not sure if changing pullies would make that big of a difference and the weight is also an issue. We're about 40lbs overweight now...guess I could drop a few pounds, although I'm not getting into that with her... :-)
post #4 of 20 (permalink) Old 03-26-2012, 10:03 AM
I don't believe changing pullies would address your problem which, as I read it, is that you simply need more power to haul everything you need to haul. Pullies won't provide any extra power; they simply distribute better the power that you have. If you can afford it and you plan on doing a good number of these long, luggage-laden rides, I think you're on the right track in your thoughts for upgrading in size/power.
( Used to have: )
'08 Vulcan 900 Custom:
*Passion Red *Mustang One-Piece Vintage Seat
*Hard-Krome 2.5" Strippers with Smartpartz Hard Kore Baffles
*Cobra Short Sissybar, Pad & Insert *Leatherworks 312 Chopper Bag *Small/Med. Windshield
at-home-daddy is offline
post #5 of 20 (permalink) Old 03-26-2012, 10:38 AM
Heavy, I love my V9D; handles well, 50 mpg, dead dependable, can keep up with the 1500 and up crowd with just a little spurring. However.........
We 2-up a lot also. I'm 270, so with her on, we break over the 400 lb limit by 20 pounds. The bike seems to handle it just fine, chassis, engine and brakes. We took off the stock sissy bar and put on a trunk, which slid her back about 3 inches. I can feel the difference in weight placement going in a straight line (weight feels further back than last year); we haven't done any touring yet, and the little she has been in the bike this year so far with the trunk has changed the handling a little in the twisties. Maybe I just need to readjust to the new feel. But on the larger bikes (Vulcan 1700, Vstar 1300), she still sits forward of the rear axle, whereas now on the V9D she is just about now on top of it. If your lovely has enough room as it is now, shouldn't be a problem; never had an issue in the twisties with the lovely on and the stock sissy bar.
Also depends on what type of touring you plan to do. I put a slightly taller rear tire (170/80 versus the 180/70) and that helped reduce the revs in top gear slightly; I don't have any plans to put on a different pulley, but I might go darkside. The bike will pull us 2-up to a top speed of 105 mph, but above 80 mph she starts buzzing a bit more than I like. If low speed (70 and under) touring is in you furture, which is my preference, then the 9 should be fine. If you plan on high speed, lots of distance touring, then bigger might be better.
As for power, I've not done much in that regard (stock pipes debaffled, K&N in stock box, Amsoil), but 2-up, at 60 mph, all I really do is just roll on and she goes just fine. If I want to get going, I drop her to 4th and she really takes off. I've not yet encountered a situation where I really needed more power. Even all of the mountain passes I go through haven't been a problem.
Is there a bigger bike in my future? Yes. I want to do more of the high speed touring down the road (a lot more the the US I want to see). I'm looking at least 1300 V-Twin or larger. But for what I do now and what I plan on doing for the next 6 years or so until all the kids are out of school, the way I have my V9D set up works perfect for me.
2006 VN900 Classic LT - Red and Black
Stage III Stock Pipes - K&N Filter in Stock Box - Amsoil - 170/80 Kenda Kruz - Saddlemen Explorer - Willie & Max Windshield Bag - Mutazu Passenger Floor Boards - Shorai Heavy Duty Battery - Kawasaki Lowers - Black Universal Trunk mounted on Mutazu Rack - Osram 70/65w Plus 50
King43 is offline
post #6 of 20 (permalink) Old 03-26-2012, 10:53 AM
Color: Orange SE
My suggestion is to try it. Do a 100 mile trip or something two up with a fair amount of luggage. Two up we overload her too, but I think it does fine (the high rev's don't bother me).
If you don't like the way it handles, then upgrade. You'll be able to do some, but not much to it. In my opinion, putting pullies, pipes, intake, etc. is a way to make a bike you already love that much sweeter. If you find on your 'test trip' you are severely limited or uncomfortable, you're not going to be able to do anything to make you not feel that way anymore, except go with a bigger bike.
My $0.02 anyway.
Romans5.8 is offline
post #7 of 20 (permalink) Old 03-26-2012, 11:20 AM Thread Starter
HeavyDrop's Avatar
thanks for all the advice...we're going on a 200mi trip in late April, we'll see how she handles the mountainous roads ahead.
post #8 of 20 (permalink) Old 03-26-2012, 07:07 PM
whiting57's Avatar
To get a true indication of how the nine tours .. go into the rides section on here ... look up bustin bugs in the search mode ... mine rolling 2up is over 1260 lbs loaded. Remember ... its what you are happy with.
whiting57 is offline
post #9 of 20 (permalink) Old 03-26-2012, 07:29 PM
Color: Orange SE
+1. I don't feel limited.
Last edited by Romans5.8; 03-26-2012 at 08:29 PM. Reason: Replied to the wrong thread, whoops!
post #10 of 20 (permalink) Old 03-26-2012, 08:27 PM Thread Starter
HeavyDrop's Avatar
well, I'm going to put my worries aside and put our 9 through the paces over the coming months. You all have provided sound advice and I appreciate you all sharing your experiences. Glad to be a part of such a great crowd.
Bigger moter, bore it out, bigger cam?? Thriller E Engine Work 42 03-04-2014 09:04 PM
Looking into bigger bike rick Other Motorcycles 4 12-20-2012 05:47 AM
If you were going to get a bigger bike... Farscape Vulcan 500 35 11-03-2011 08:06 PM
Thinking about bigger bike.... Martini Man Vulcan 1600 31 10-20-2009 05:09 AM
How many 900cc owners thinking of a bigger bike? guitpic Vulcan 900 27 09-18-2009 04:53 AM
