headlight trouble - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 03-20-2012, 08:02 AM Thread Starter
ronc09's Avatar
headlight trouble
my low beam head light seems to be very dim, and when on low beam the high beam light is dimmly lite. when i switch to high beam every thing seems to work fine . high beam seems normal . ive changed the bulb and it didnt seem to make a difference. any ideas why the high beam dummy light would be dimmly lit on low beam.
ronc09 is offline
post #2 of 7 (permalink) Old 03-20-2012, 08:53 AM
It's acting like it has a bad ground (-) connection in the lowbeam circuit. I'd start there first.
Good Luck!
2008 Classic LT
GearDoctor is offline
post #3 of 7 (permalink) Old 03-20-2012, 10:31 AM
Bear2123's Avatar
Dim light
Good Luck!
+1 on that ground. Clean all the connections as well.
Then tell us what you found and what, if anything, worked.
Bear2123 is offline
post #4 of 7 (permalink) Old 03-20-2012, 10:57 AM
Sounds like the culprit is the dimmer switch. Also check the plug located on the frame backbone under the tank. Is the hi-beam indicator lit too when on low beam?
Sojourner is offline
post #5 of 7 (permalink) Old 03-20-2012, 02:20 PM
BOTM Winner, December 2013
big worm's Avatar
he answered that question in his first post.......
when on low beam the high beam light is dimmly lite. any ideas why the high beam dummy light would be dimmly lit on low beam.
big worm is offline
post #6 of 7 (permalink) Old 03-20-2012, 08:54 PM
Sorry I overlooked that. Cross-talk most likely in the switch but checking the wiring down to the plug connector under the tank can't hurt.
post #7 of 7 (permalink) Old 03-21-2012, 09:20 AM Thread Starter
ronc09's Avatar
thanks for the help guys but i think i figured it out .....and im afraid to say it but it was stupidity on my part. I have an after market headlight on my bike and the bulb burned out at the end of last season so i pretty much changed the bulb and parked the bike for winter. seems as thought when i changed the bulb i turned the plug around. the style of the plug allows you to actually plug it in turned around backwards. Now if that wasnt bad enough it seems when i changed the bulb again to try to fix the problem ...guess what i installed in backwards again...lol found this out yesterday reversed the plug and all seems to be well now. thanks again for the help.
ronc09 is offline
800 Vulcan headlight trouble Jessdogg Vulcan 800 14 09-26-2013 01:05 PM
Vulcan 800 headlight trouble Jessdogg General Vulcan Talk 5 09-25-2013 09:53 AM
99 1500 drifter headlight trouble dtmmil Vulcan 1500 1 06-13-2013 09:45 AM
trade my aftermarket headlight for stock 900 custom headlight doughrek Bikes For Sale 2 07-17-2011 12:02 AM
WTT cyclopse / wave headlight & mount for stock vulcan 900 headlight & mount doughrek Wanted to buy or trade Items 0 06-09-2009 12:20 PM
