Crush washer reminder. - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 03-19-2012, 06:49 AM Thread Starter
silenthill's Avatar
Spring is upon us...and changing the oil in our nine's is upon us too.
Just a reminder about the crush washer on the drain bolt. It will often stick to the bottom of the oil pan....then fall into the drain pan. If u forget to "fish" it out of the drain pan and then put your drain bolt back in and tighten...u run the risk of oil-leakage...and or wrong torgue which could lead to the dreaded thread strippage that everybody worries about. Just a friendly reminder guys/gals!
Ride safe!
Regards, S.H.
2009 VN900 Classic LT.
Nova Scotia, Canada.
Cobra luggage rack.
Kuryakyn Grand Tourer luggage bag.
Kuryakyn air filter cover.
170/80/15 Metzler rear tire.
Fire and Ice passenger floorboards.
Stage 2 debaffle (screens left intact).
silenthill is offline
post #2 of 5 (permalink) Old 03-19-2012, 09:26 AM
Bear2123's Avatar
Crush washer
Thanks for the reminder. I actually found a great local honda dealer, Fox Valley Cycles, in Aurora, IL, who attaches one to each filter when I buy them. Great reminder and a fresh crush washer is used each oil change.
Bear2123 is offline
post #3 of 5 (permalink) Old 04-09-2012, 06:35 AM Thread Starter
silenthill's Avatar
Decided to "bump" this as I just read somebody lost their crush washer in the drain pan. One can't underestimate the risk of over-torquing with no crush washer taking up tolerance and stripping the treads in the oil pan. I've seen it happen! A friend of mine kept having a small leak....knew nothing of the crush gasket as it had dropped into the drain-pan....and out of frustration over tightened the bolt to "stop" the leak.....he ended up with stripped threads and a BIG hastle on his hands....It's an easy mistake if you don't realize you've lost the crush washer!!!!
Cobra luggage rack.
post #4 of 5 (permalink) Old 04-09-2012, 09:22 AM
Pretzel's Avatar
Poignant reminder! PLUS, remember if you re-use a crush washer, flip it. Even frugal me won't use one more than twice, though, as when it's compressed it loses it's "tolerance".
LED Run/Turn/Brake
Vance and Hines Duals
Dobeck TFI
Vista throttle lock
Pretzel is offline
post #5 of 5 (permalink) Old 04-09-2012, 09:57 AM Thread Starter
silenthill's Avatar
Pretz...u shouldn't flip it.....then the indented side will be against the oil pan face....u need the flat side so it's flush. Better to use it twice without flipping.
Regards-sh.
It's been my experience that the crush "dents" on the nut side of the bolt.....however, u could be right as well!
Cobra luggage rack.
Crush Washer 1999Vulcan1500 Oil and Lubrication 1 09-19-2011 06:57 AM
Help. Turn signal reminder wiring Sailor Bill Vulcan 900 18 07-06-2011 03:16 AM
grim reminder geno2k General Vulcan Talk 7 05-13-2011 02:20 AM
Crush Washer? ChrisM Vulcan 500 3 10-14-2010 08:18 AM
Rider down, and a Reminder dan20164 General Vulcan Talk 5 06-25-2010 07:23 PM
