stiff kickstand - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 03-13-2012, 10:00 AM Thread Starter
CycleDude's Avatar
stiff kickstand
S'up everyone?
Been a lonnnng time since I was here, but I have a question.
I was riding my 06 900 last night, enjoying a freak 70* day here in NJ, when I noticed something odd. My kickstand was REALLY stiff... Like, I had to WORK at lowering it. I know I'm outa shape, but that's ridiculous.
It rained today, so I dont have the bike nearby to look at it, but has anyone ever experienced this kinda thing before?
CycleDude is offline
post #2 of 10 (permalink) Old 03-13-2012, 11:39 AM
Pretzel's Avatar
I've heard of the 900 dropping it's spring, allowing the kickstand to flop around a bit. I had to have mine welded solid, re-drilled and fitted with a bushing to keep the spring in place to solve the aforementioned "flop", as the original mounting hole had worn out a bit, and I've seen quite a few people with that issue. Perhaps in your case it slipped without dropping off the stand and is catching on something?
LED Run/Turn/Brake
Vance and Hines Duals
Dobeck TFI
Vista throttle lock
Pretzel is offline
post #3 of 10 (permalink) Old 03-13-2012, 12:00 PM
Jeep Pirate's Avatar
Stiff kickstand? I usually get that problem when I am at a bikini contest!
No seriously, I have heard of folks with this issue. Like is stated above, there is some issue with the spring coming loose or something. I think the bushing where the stand spins wears out and puts it in a bind. Some folks have had the stand actually fall of its own accord while riding which can be interesting. I think if you search kickstand on the forum, you may find some threads on this.
Good luck!
'07 VN900 Classic
Horsepower is an illusion.
Jeep Pirate is offline
post #4 of 10 (permalink) Old 03-13-2012, 12:15 PM Thread Starter
CycleDude's Avatar
Oddly enough, I have used that as "a line" on my wife goofing around...
Thanks, I'll check out that bushing.
post #5 of 10 (permalink) Old 03-13-2012, 12:21 PM
Color: Orange SE
Although your issue sounds more serious, I had something similar. After a rain, it was feeling 'odd', very stiff. The next day, I went to get it safety inspected. I about tripped when I kicked the kickstand out and it FLEW. I guess the shop guy noticed my surprise and said "Oh yeah, you had some grime caked in there so I cleaned and lubed it"
Before you order any parts... might be worth a look to see if it's something simple like that!
Romans5.8 is offline
post #6 of 10 (permalink) Old 03-13-2012, 01:01 PM Thread Starter
CycleDude's Avatar
Yup... Theres evidence of scarring down to bare metal.
*sigh*
post #7 of 10 (permalink) Old 03-13-2012, 01:20 PM
Banned
The side kickstand is one item many neglect to apply oil to lube the shaft
Degreaser is offline
post #8 of 10 (permalink) Old 03-13-2012, 01:49 PM Thread Starter
CycleDude's Avatar
Looks like a simple DIY project. One-bolt disassembly, lube the shaft and paint the bare metal to prevent it from rusting any worse, right? Any particular type of lube to use?
post #9 of 10 (permalink) Old 03-13-2012, 01:58 PM
Banned
engine oil or whatever you have handy, put oil around the pin/shaft and work the oil into the pin/shaft by moving the sidestand up and down, then add more oil and repeat until the oil is worked to down inside the pin/shaft, no need to disassemble it
post #10 of 10 (permalink) Old 03-13-2012, 02:13 PM Thread Starter
CycleDude's Avatar
Coolio. Thanks, dude. I can sometimes complicate little things. A couple of squirts of wd-40 and she's like butter.
Stiff front suspension redfish Vulcan 1500 3 07-19-2015 07:29 AM
Stiff neck! Big Dave Vulcan 1700 33 03-26-2014 10:47 AM
Harley to face stiff competition Old Syko The Lounge (Off Topic) 11 04-18-2013 06:25 PM
Stiff throttle Ol'Yella Vulcan 900 4 04-11-2012 11:18 AM
Stiff Clutch kow_grl Vulcan 900 6 12-06-2008 10:45 AM
