230 Tire w/SW Rear Pulley Thought Pls. - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 03-12-2012, 12:21 PM Thread Starter
Thought please on this combination on '09 900 Custom.
IGGY is offline
post #2 of 10 (permalink) Old 03-12-2012, 02:43 PM
gillisfire20's Avatar
Rear pully? Don't know of anyone that has done it. Front pully doesn't work since it is larger and moves the tire forward. I think the rear pully is smaller so I would think it may give a little extra room. But again, I don't know.
His '04 Nomad 1500
His '09 Vulcan 900 Custom SE
Hers '08 Suzuki C50
In work 1979 Honda CB750K
BIMC Louisiana
gillisfire20 is offline
post #3 of 10 (permalink) Old 03-13-2012, 09:21 AM Thread Starter
Re; Pulley (Pulleys)
I gleaned this from KawasakiMotorcycle.org....
230 tire can be used w/o pulleys
230 tire can be used with rear pulley (tire moved back 1 1/4 -1 1/2")
230 tire can be used with both pulleys
230 tire CANNOT be used with front pulley (dangerous rubbing)
IGGY is offline
post #4 of 10 (permalink) Old 03-13-2012, 02:04 PM
go for it! Let us know how it does. That would drop the rpms real nice at 75 mph
2009 Vulcan 900 custom SE
-zixxer- is offline
post #5 of 10 (permalink) Old 03-13-2012, 04:04 PM
"230 tire can be used with both pulleys
230 tire CANNOT be used with front pulley (dangerous rubbing)"
Is it just me or this a little contradictory? I would really like to know if the rear pulley can be used because I have a 230 rear tire and it would still help alot on the hi-rev issue.
Do it and fill us in on the results. I'll be the next one to try it out.
Sent from my Motorcycle iPhone app
Blind men don't fear snakes in the grass...
_____________________________________________
2008 Vulcan 900 Custom
V & H Slash Cut Staggered
ISO Grips, Pegs, Stiletto End Caps
Irate Customs Radiator and Regulator Grill
Kuryakyn Bullet Tail Lights
Clear Tail Lense
Swing Arm Bag
Front Tool Bag
Clear Turn Signals
Cobra Headlight Visor
Avon 230/60 15 Roadrunner
LA Choppers Lowering Kit
More to come...
atineo1982 is offline
post #6 of 10 (permalink) Old 03-13-2012, 04:12 PM
Banned
The 900 stock pulley is fine, do not change it
Degreaser is offline
post #7 of 10 (permalink) Old 03-13-2012, 08:00 PM
"Is it just me or this a little contradictory?"
He is saying that with the 230 set up that:
Yes you can use the rear pully only (moves tire back lowering rpm)
Yes you can use the rear pully and the front pully together (tire stays in original position but lowers rpm)
No you can not use the front pully only (moves tire forward causing rub making bike go crash boom bang)
His '04 Nomad 1500
Hers '08 Suzuki C50
BIMC Louisiana
post #8 of 10 (permalink) Old 03-13-2012, 08:00 PM
The front pulley is a larger circumference thus pulls the tire forward, a 230 tire will rub on the swing arm and mud guard.
The rear pulley is a smaller circumference thus pulls the tire back.
When used together they equal out and the tire remains centered and away from the swing arm.
And yes I know this for a fact. I have both.
John
"I am a modern cowboy, on a steel horse I ride"
09 VN900 Classic
Big 3 +++++
Double Darkside
Bytehead is offline
post #9 of 10 (permalink) Old 03-13-2012, 08:47 PM Thread Starter
Bytehead: ur right
I should have been more detailed. The reason I am going with the rear pulley (and have ordered) is because the pulley will move the tire more to the rear and provide room for 230 if lowering 2", better mileage and know doubt aesthetics. I am not saying that it my intention ov lowering, but option is there. I like the Metz 200 and am going to run it for awhile. Just going to take it a step @ a time ($).
A competitor likes the look ov our Customs (nice Blackline).
Also, for some that have had issue with Scootworks, I ordered a week ago, and because ov those issues I e-mailed them this afternoon re; shipping date. I got a response within 50 minutes. Shipping clerk e-mailed saying that they were a little behind...it will be on dock by end ov week and he will e-mail tracking #.
Guess we'll C.
IGGY is offline
post #10 of 10 (permalink) Old 03-13-2012, 09:31 PM
Guess we'll C.
I assume you went for the shinny one on a custom I WOULD
I can tell you the rear pulley will make both the 200 and 230 look much more pleasing, the empty space between the tire and fender is gone. And you should be aware it will change your speed o, with the 200 already and the pully you will be at -7.23 overdrive, or so says gearingcommander.com, This will make your speed o change along with the obo. Just check it against a known unit, will probably be showing on the low side of actual. Just be aware of it so as not to see bright lights behind you.
I will not bore you with my tales of ScootWorks but good luck with that.
John
09 VN900 Classic
Big 3 +++++
Double Darkside
Bytehead is offline
A little rear tire help pls... CptCrusty1 Vulcan 1600 6 08-05-2014 06:20 PM
170/80/15 rear tire with SW front pulley gmer140 Vulcan 900 8 06-23-2012 10:29 AM
Advice Pls. Scootworks Rear Pulley IGGY Vulcan 900 14 03-09-2012 07:47 PM
SW front pulley and 200 tire???? jimmy77611 Vulcan 900 4 04-30-2011 12:11 AM
SW rear pulley and 200 tire? NorThai Vulcan 900 8 04-29-2011 07:15 PM
