V900 wireing - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 03-11-2012, 12:47 PM Thread Starter
V-Rider's Avatar
V900 wireing
I'm sure these threads are here but I'll ask anyway. I have not taken the headlight apart yet but I have read that there is an accessory wire in there. Is there only the one and what color is it? Under the seat there is suppose to be an accessory wire too, what color would that one be.
I am adding an accessory outlet for a GPS on the front and a trunk with lighted(LED) spoiler on the rear. If anyone has done either and has any pics or tips you would have would be appreciated.
I am looking for a chrome accessory plug to mount to the handle bars if anyone knows of where to pick that up.
V-Rider is offline
post #2 of 4 (permalink) Old 03-11-2012, 01:37 PM
The accessory circuit in the headlight and under the seat are both red and black wires with bullet connectors that are white.
BE ADVISED THIS CIRCUIT IS ALWAYS ON, DIRECT WIRE TO BATTERY.
And you should not hook up more than 70 watts extra load to the charging system.
The GPS you mention should be wired to a switched circuit and the trunk needs to operate from the running light circuit.
This works great for a power point and is great looking. Pricey but I like it.
http://www.cruisercustomizing.com/ku...s/part/KY-1423
John
"I am a modern cowboy, on a steel horse I ride"
09 VN900 Classic
Big 3 +++++
Double Darkside
Bytehead is offline
post #3 of 4 (permalink) Old 03-11-2012, 03:01 PM
[/URL]
Do they have other mounting locations? I wouldn't want a fixed outlet on my bars. And is this a switch or is it always on? This can be connected to the battery tender?
Sent from my Motorcycle iPhone app
Blind men don't fear snakes in the grass...
_____________________________________________
2008 Vulcan 900 Custom
V & H Slash Cut Staggered
ISO Grips, Pegs, Stiletto End Caps
Irate Customs Radiator and Regulator Grill
Kuryakyn Bullet Tail Lights
Clear Tail Lense
Swing Arm Bag
Front Tool Bag
Clear Turn Signals
Cobra Headlight Visor
Avon 230/60 15 Roadrunner
LA Choppers Lowering Kit
More to come...
atineo1982 is offline
post #4 of 4 (permalink) Old 03-11-2012, 04:02 PM
This unit is permanent mount on handle bars and I wired direct to battery, comes with a 10 amp fuse. Also has an old style cigarette lighter included. So if I use it I have to unplug or turn off when the bike is off. It can be wired to a switched circuit but I took the easy route. Works well, the cap is tight and looks good to boot. Can be used to power most electronics used today including recharging your cell phone.
Do not connect to battery tender, been there done that , the battery tender fuse is 3 amp and quickly magic smoke appears.
John
09 VN900 Classic
Big 3 +++++
Double Darkside
Bytehead is offline
spotlight wireing cobra 1 Vulcan 900 2 02-06-2013 03:24 PM
dual headlight wireing daddy07 Vulcan 900 4 02-17-2011 06:32 PM
wireing up F&S light bar vulcanater Vulcan 2000 5 06-10-2010 07:20 PM
Problem With Wireing On Bike boxalarm222 General Vulcan Talk 13 05-02-2009 09:15 PM
HELP 96 Vulcan 800 classic...handle bar wireing read on llcelebrity Vulcan 900 7 03-23-2009 12:11 AM
