Spark Plug Wires - Kawasaki Vulcan Forum : Vulcan Forums
LinkBack Thread Tools
Old 03-02-2012, 07:19 PM Thread Starter
Question Spark Plug Wires
Anyone know if there is a service recommendation for changing out the plug wires? I've changed the plugs at the recommended intervals,(12,000 miles, I believe) but don't remember seeing anything in the wires...... Are they an easy change out or are they part of a coil pak that has to be changed at the same time.. I'm looking at my 32,000 valve check, at that would be the time to make the change if needed....Thanks in advance for your assistance......
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting'..... “what a ride”!' George Carlin
kawa afterthought is offline
Old 03-02-2012, 09:00 PM
Looking at the Kaw service Manuel at the periodic maintenance table under replacement parts there is no mention of plug wires. As far a valve clearance my Kaw owners manual says 26kmiles while the service manual says says 15kmiles for US & CA. I would like to know what our fellow 9 owners are doing as far a valve clearance adjustment intervals?
mdsimon80 is offline
Old 03-03-2012, 09:22 PM
I have checked on ordering just the plug wires. You can order the boot ends separately, but in order to get the wires/boots you have to order the coil packs...they come as a complete package deal.mdsimon80,as far as the valve clearance I had my mechanic check mine for the first time at 31,000 miles and he said very little shimming was needed only .002 on front intake, and .001 on rear intake
xxxxxxRTL Rider is offline
Old 03-03-2012, 11:54 PM
Color: Orange SE
The valve job seems to vary. Some do it to a tee according to the manual, some put 100,000 miles on the bike without touching it, others wait for it to make a noise. Still others have never heard of needing a valve adjustment!
As for me, I try to stick with the manual. Although from what I've been reading, it seems like the first clearance adjustments (15k I believe) are the most drastic. So, if I were gonna skip 'em, I'd skip AFTER the first one, in other words, I would recommend thinking about doing it / getting it done at 15k miles.
It's one of those things that you could never do for the life of your bike and never have a problem. OR, you could put 35,000 miles on it without doing it and end up with an expensive top end job. Depends on which you feel like you've got better odds for I guess! LOL.
Romans5.8 is offline
Spark plug wires mska1092 Vulcan 900 0 03-22-2013 03:58 PM
12mm Spark Plug Wires M.Ciulla Vulcan 1500 1 03-04-2013 08:03 PM
Spark plug wires?? classiccruiser Engine Work 3 11-30-2012 11:07 AM
Vulcan 800 Spark Plug Wires acpd22 Bikes For Sale 0 02-06-2012 12:22 PM
Spark plug wires: are the boots a separate piece? Mambo Dave Vulcan 800 2 06-01-2011 07:26 PM
