Removing the turn signals? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 02-28-2012, 01:13 PM Thread Starter
twp
twp's Avatar
Have a question. Do the rear turn signals have a plug some where on them? I was wanting to take mine off and see about moving them , but could not find a plug on them. I do not want to cut the wires.
twp is offline
post #2 of 5 (permalink) Old 02-28-2012, 06:32 PM
bigsarge2012's Avatar
you gotta cut the wires, no plug.
bigsarge2012 is offline
post #3 of 5 (permalink) Old 02-28-2012, 07:06 PM Thread Starter
twp
twp's Avatar
That stinks. I realy don't want to cut the wires.
twp is offline
post #4 of 5 (permalink) Old 02-29-2012, 03:38 AM
The plugs are under your seat, in front of the tool box. Just follow the wiring that comes through the rear fender on the right side of the tool box. Look for two plugs, one with gray and black/yellow wires, the other with green and black/yellow wires.
Sojourner is offline
post #5 of 5 (permalink) Old 02-29-2012, 11:45 AM Thread Starter
twp
twp's Avatar
Thanks Sojourner I will check an see how hard they are to take out.
twp is offline
Retrofit LED Lamps for Existing Turn Signals- Turn Signals 101 rangemaster728 Vulcan 650 S 32 02-03-2018 04:12 PM
Rear Turn Signal Problem - Old Signals Work - Replacement Signals Don't merc Vulcan 500 9 06-17-2015 10:01 PM
Help Removing Front Turn Signals richbloom Vulcan 900 4 07-26-2013 02:50 AM
Changing rear turn signals to run-brake-turn Blue Vulcan 900 5 04-01-2013 11:07 AM
Rear Turn Signal Connection Aftermarket Turn Signals dccatfan General Vulcan Talk 7 03-18-2012 05:04 PM
