Handlebar riser screw lost.... - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 02-24-2012, 08:24 AM Thread Starter
Last night I decided to put my new handlebar risers on my classic. Got everything off fine, but when I went to put the screw back in the bottom of the triple tree it fell somewhere. Its somewhere under the tank. I opened up the headlight and looked in there, but its not there. I am guessing it fell under the tank, so I guess I have to take the tank off and try to find it. I know its a long shot, but has this happened to anyone else before?
I have extremely large fingers (size 19 ring), so I am going to have my wife start the bolt after I find it. Just wondering if anyone might have an idea of where it might have fallen into.
2009 Vulcan 900 Classic
chum1600 is offline
post #2 of 3 (permalink) Old 02-24-2012, 10:59 AM
Jeep Pirate's Avatar
There is a bit of space under the tank but on top of the square center tube of the frame. If you can get one of those extendable magnets on a stick in there, you might pick it up. Of course, you might also stick to the frame, the tank, etc. If you don't find it there, check between the jugs. It is possible for something to ride down the frame rail and fall in between the jugs. There's actually quite bit of room in there. Good luck.
'07 VN900 Classic
Horsepower is an illusion.
Jeep Pirate is offline
post #3 of 3 (permalink) Old 02-24-2012, 11:29 AM
OverHillAndDale's Avatar
I usually find my missing screws in the specialty metric screw sections at Lowe's or Home Depot!
Dale
2010 Vulcan Voyager /Ooops - I totaled it!/
OverHillAndDale is offline
Has anyone installed a Handlebar Riser on the Voyager??? Nerdybiker Vulcan 1700 8 03-20-2016 05:08 AM
Vulcan 500 LTD gear shifter lost tightening screw! Juancho Vulcan 500 5 10-29-2013 02:45 PM
Handlebar/Riser/Grips question drgck Vulcan 900 3 05-22-2013 10:30 PM
handlebar/riser change on V2K LTD vulcanjunkie Vulcan 2000 6 10-16-2012 12:58 PM
3 general question! Handlebar/Riser/Shocks Evil Scotsman General Vulcan Talk 8 07-17-2010 01:21 PM
