Lost all power!! - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 18 (permalink) Old 02-21-2012, 01:24 PM Thread Starter
Unhappy Lost all power!!
I went to start my 2007 900 Custom yesterday. I turn the ignition and power comes on. I press the starter and the engine starts to turn over...and then everything goes dead. I turn the ignition off and then on again, and no power. I don't even get lights on the gauges.
I've checked all the fuses in the 10 and 15amp fuse box including the 30 amp ignition fuse. All are good. I took the battery to Advanced Auto Parts and they say its a good battery and they are charging it for me (I'll pick that up this afternoon).
I'll put the battery back in tonight and see what happens. If I still don't get power, what else should I look for?
bassman99 is offline
post #2 of 18 (permalink) Old 02-21-2012, 01:31 PM
Starter relay ???
Bad Juju is offline
post #3 of 18 (permalink) Old 02-21-2012, 01:40 PM Thread Starter
Would that prevent any power from coming on?
post #4 of 18 (permalink) Old 02-21-2012, 02:27 PM
No. Wait for you battery. That may fix you problem, at least temporarily, anyways.
Post back with your results.
sfair is offline
post #5 of 18 (permalink) Old 02-21-2012, 08:11 PM Thread Starter
Ok, so I got my battery back from Advanced Auto Parts. When I picked it up I had the guys check it first. Their equipment came back with a reading that the battery was good, but that it needed to be fully charged. This is after it had sat on the trickle-charger for 24 hours. All the AAP guys and me knew this should have given it a full charge.
In any case I took it home and put it on my bike. Put in the key, turned it on, and I had power!! Engine turned over and everything works great. I hooked up my volt meter to the battery and it showed the battery holding at 12-13 volts. I revved the engine and it rose to 13-14 volts. So the only conclusion i can draw is that the battery is taking a charge, but not holding a charge. In which case it looks like a new battery is going on my tax refund wish list.
post #6 of 18 (permalink) Old 02-22-2012, 04:03 AM
A smart charger would be prudent right now if you want the battery to eek out another month or two. A good test of your battery holding a charge is taking a reading the day after you've ridden the bike a fair distance. With everything turned off, the battery should be above 12.6 VDC.
Sojourner is offline
post #7 of 18 (permalink) Old 02-22-2012, 05:42 AM Thread Starter
I need to ride it to work today, so when I get home I can check that.
post #8 of 18 (permalink) Old 02-22-2012, 10:09 AM
Key off voltage does not tell one much, key ON voltage much more meaningful.
sfair is offline
post #9 of 18 (permalink) Old 02-22-2012, 10:22 AM Thread Starter
Which means I should check all 3 (key off, key on, and engine on) just to be thorough. In any case, unless something weird come sup, a new battery is in my future.
post #10 of 18 (permalink) Old 02-22-2012, 10:32 AM
How is that if you have no idea what the load is?
Lost my braking power in the front .. Need help w troubleshooting 10grandstan Vulcan 500 17 11-27-2015 08:59 PM
99 Vulcan 88 running rich, surging then lost all power ditchdoc Vulcan 1500 0 04-30-2013 04:36 AM
Lost power michaelingeorgia Vulcan 500 2 05-07-2011 11:16 AM
Lost all my oil thru vent hose grasshopper888 Vulcan 900 3 10-02-2010 01:47 PM
lost all electrical robbie7045 Vulcan 750 6 05-29-2010 04:51 PM
