Grumpy. New seat won't work with my backrest! - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 24 (permalink) Old 02-13-2012, 08:11 PM Thread Starter
Chupa's Avatar
Just got my Mustang wide touring seat for my 09 Custom today, and it won't fit with the Kawi backrest/rack. The seat is too long, won't latch down, and digs into the backrest. Anyone else had this problem?
Not sure what to do...find a different seat, or find a different backrest. I have the SE, and the black Kawi backrest looks really good on there. Almost no chrome on the bike, so I'd need another black backrest. Any suggestions would be great.
09 Custom SE
Don't sweat the petty things, just pet the sweaty things!
Chupa is offline
post #2 of 24 (permalink) Old 02-13-2012, 08:28 PM
I have the same problem. I like the look of the backrest and luggage rack so when the weather gets a little better I am going to a local shop that does custom work on seats. I would do it now but I want to take the bike with so they know what I want them to do with the seat.
08custom is offline
post #3 of 24 (permalink) Old 02-13-2012, 09:34 PM
diehard rider's Avatar
What kinda backrest do you guys have, one of those real short backrest or what I call buttrest? Here's a pic of a custom se a buddy had and there's plenty of space between the Mustang and his backrest. [IMG][/IMG]
2012 GREEN/BLACK VAQUERO
Kawi Quick release backrest
Kawi Passanger floorboards
Kawi Luggage rack
Klockwerks 9" windshield
Mustang Seat
Mustang pass backrest pad
Ipod adapter kit/Ipod
Black ISO Grip
Offset ISO highway pegs
PC5 W/ignition
Freedom Performance True Dual Exhaust
Altrimax HP 195/55/16 car tire.
Leather saddlebag chaps
Thunder mfg Tornado air intake
Thunder mfg Throttle Body Gasket
diehard rider is offline
post #4 of 24 (permalink) Old 02-13-2012, 09:48 PM
This is the back rest I have. you can see where it is hitting. Is this the same problem you are having Chupa?
08custom is offline
post #5 of 24 (permalink) Old 02-14-2012, 07:44 AM Thread Starter
Chupa's Avatar
Yep. Same problem. I guess I'll have a backrest for sale soon.
09 Custom SE
Chupa is offline
post #6 of 24 (permalink) Old 02-14-2012, 10:12 AM Thread Starter
Chupa's Avatar
Figured it out. Just gonna redrill the mounting holes and move the whole thing back 2 inches. Then fill the old holes with some pretty bolts or small plastic plugs.
09 Custom SE
Chupa is offline
post #7 of 24 (permalink) Old 02-14-2012, 12:18 PM
I would have never thought of that. when you get the mod done you should put some pics up so I can see how it looks. Maybe you will same me some money.
08custom is offline
post #8 of 24 (permalink) Old 02-14-2012, 01:01 PM Thread Starter
Chupa's Avatar
I looked a little closer on my lunch break, and the hole at the front is to close to the edge to drill another hole. There might be enough room if you oval it out a little, but I still have to take some measurments. Or, I've got some 3/16th X 1 1/2 inch aluminum strapping, so maybe I'll try and make some extended brackets for the front. Eather way, it'll be a couple of weeks before I can tackle it.
I'll keep you posted.
09 Custom SE
Chupa is offline
post #9 of 24 (permalink) Old 03-02-2012, 09:15 PM
A mustang seat solution
I bought myself a mustang seat for xmas and had the same problem. Major dissapoinment. After enough thought, I came up with the following solution. I removed a dozen rivets from back (underside of seat). Pulled seat cover back. pushed foam out of the way, and using a dremel tool, cut 1-1/2 inches off the back of the seat. I also made the back corners where it was hitting backrest much larger diameter. I then stretched the cover back and used small screws to hold in place. Looks factory! No more rubbing or hard to remove/replace seat.
I joined this forum tonight because of you two with same problem. I hope you still have your seats. I can sent pictures of mine if you would like.
SGTLOUUU is offline
post #10 of 24 (permalink) Old 03-02-2012, 09:24 PM
Thanks for the info. Could you please post the pictures I would like to see how it looks.
08custom is offline
Will the OEM backrest work with Mustang DayTripper seat? westcoastkevin Vulcan 900 8 03-24-2017 05:11 PM
Headlight won't work nursedonna Vulcan 900 8 01-13-2013 01:33 PM
Bike won't start after riding. (Carb work done) Famliman Vulcan 1500 2 10-15-2012 08:46 PM
Grumpy's Extenders foxbat General Vulcan Talk 0 01-30-2011 05:42 PM
grumpy en500 rider satinseat New Member Introductions 4 04-25-2010 01:35 PM
