width between fender bolts on Vulcans. - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 02-10-2012, 06:38 PM Thread Starter
I am trying to find out if, after I remove the ugly dirtbike piece from the rear of my VN900C will the spacing of the bolts be the same as on the larger Vulcans. I found a nice plate mount that fits the others. Thanks folks, I can always count on you.
Like my Mom says, you're a long time dead! Live now! Anyone have some wood that I can knock on?
Tahdi is offline
post #2 of 6 (permalink) Old 02-12-2012, 04:20 PM Thread Starter
larger Vulcans
doesn't someone know the distance on center between the bolts that hold the plate bracket/black plastic (on the vn900c) under the fender? thanks
Tahdi is offline
post #3 of 6 (permalink) Old 02-12-2012, 06:04 PM
Easiest way to clean that up is remove the reflector above the stock license plate bracket, then using the same holes that held the reflector ream them out very slightly and using the same holes move your stock licence plate mounting up and remount it in these holes. Technically you may have 1 less reflector on the back of the back than some states require but I've never had anybody questiojn this. It cleans up the appearance of the back of the bike and gets rid of that "dirt bike" look of the rear fender. I run a 200 rear tire along with this "free" mod and it really changes the overall appearance of the back of the bike. RIDE SAFE
BOBKAY is offline
post #4 of 6 (permalink) Old 02-12-2012, 07:16 PM Thread Starter
plate relocation
Thanks Bob, I saw a plate bracket that incorporates the mounts for the signals. I figured it was possibly worth a try. It would clean it up even more. I thought someone would be able to give me the on center measurements from one of the larger Kawi's that it is a direct fit for. I'll post more if I make it happen. thanks
Tahdi is offline
post #5 of 6 (permalink) Old 02-12-2012, 08:59 PM
BOTM Winner, December 2013
big worm's Avatar
if that bracket is for a meanstreak it will fit the 900 custom
big worm is offline
post #6 of 6 (permalink) Old 02-13-2012, 03:59 PM Thread Starter
fitment
that is exactly what I wanted to hear. thanks
Tahdi is offline
shock length + tire width La Douche Vulcan 750 0 07-24-2011 01:18 PM
Rear Wheel width on 2007 Custom usg436o Vulcan 900 5 04-25-2011 12:02 PM
Anyone happen to know the front wheel rim width on an 800A? Mambo Dave Vulcan 800 25 03-31-2011 08:36 AM
Rim width bigmacbkr Vulcan 1700 2 02-26-2011 07:22 PM
Increasing front tire width jayzx6r General Vulcan Talk 0 09-20-2009 11:21 PM
