baffled by the baffles! - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 18 (permalink) Old 02-05-2012, 03:17 PM Thread Starter
Harry2u's Avatar
I am trying to remove the baffles on my Cobra longs and can't get them to budge. I bought the pipes used so don't know how they were put in. I got an extra set of baffles when I purchased them and want to compare them. Also thinking of putting on the Smartpartz to quiet them. Any special tools to suggest? Maybe I am just missing something simple such as another screw somewhere connecting the baffle to the pipe? Any help appreciated. Need to quiet these babies down a little!
Harry2u is offline
post #2 of 18 (permalink) Old 02-05-2012, 05:42 PM
I don't know if you've done this already, but there should be one bolt near the end of each pipe, on the bike side. Undo it and I just stick a flat screwdriver inside, find a lip somewhere and slide the baffles out. Yours should be the same or very similar to what I have.
The Cobra quiet core baffles are on the left, standard baffles on the right.
Graybush is offline
post #3 of 18 (permalink) Old 02-06-2012, 04:59 AM
There will be one or two screws holding the baffles in place usually at 6 o'clock & 9 o'clock. Most likely it's carbon built up in the pipe and baffle that's keeping it tight. Take the pipes off and with the screws removed gently tap the end of the pipe on a piece of wood until the baffle frees up. While the baffle is out drill a 1/4" hole somewhere near the end so that you can use a piece of smooth rod with a hook on the end to pull it out next time. I've had Cobras on two different bikes, drags, sweeps & classics and they are all noisy. I tried everything and the best I could do is get some of the raspiness out of it but the DB's never changed much.
Sojourner is offline
post #4 of 18 (permalink) Old 02-06-2012, 07:35 AM Thread Starter
Harry2u's Avatar
Thanks guys. Appreciate the pics very much. It looks like I have the quiet baffles in the pipes now. I had removed the screws in the end of the pipe but thought there might be another one I didn't know about. Looks like I am going to have to remove the pipes to get the baffles out but was hoping for an easier way. Need to order new gaskets before I take them off as I have used them twice now. I am going to try the Smartpartz and see if it will help some with the noise. Heard good and bad about them so we will see.
Harry2u is offline
post #5 of 18 (permalink) Old 02-06-2012, 07:41 AM
Banned
maybe use a coat hanger and bend the end of it, reach into the baffle to hook the end of the coat hanger onto the baffle. I have the Cobra Quiet Baffles in my Cobra Dragsters, the quiet baffles lowered the decibels about 4 to 5 decibels, the dragsters are still load but better than before, the quiet baffles will create a bit more back pressure to the engine
Degreaser is offline
post #6 of 18 (permalink) Old 02-06-2012, 08:19 AM
Tank27949's Avatar
I ended up having to drill the bolts out of mine when I changed to Quiet Core baffles. Then I had to re-tap to the next size up. Use some nickel anti-seize when you put'em back together. I did and they haven't vibrated loose or anything yet.
2007 900 Classic LT(SOLD)
Tank27949 is offline
post #7 of 18 (permalink) Old 02-06-2012, 09:25 AM
Degreaser's got the right idea and since you have the quiet baffles you have some big holes that you can slip a hook into. The coat hanger is probably a bit soft for the application so I would stop by a welding shop and buy some brazing rod that you can bend a hook on the end and a loop on the other. I would try that first before removing the pipes.
post #8 of 18 (permalink) Old 02-06-2012, 05:27 PM Thread Starter
Harry2u's Avatar
Not giving up just yet. Will try the hook thing for sure. Thanks.
Harry2u is offline
post #9 of 18 (permalink) Old 02-06-2012, 06:52 PM
Banned
I just don't get you guys and your quiet pipes . . .
flywithlloyd is offline
post #10 of 18 (permalink) Old 02-06-2012, 07:00 PM
Banned
I had a dilemna, because when I bought my bike with quiet stock pipes I wanted a bit more punch to the sound of the exhaust, so I bought V&H Longshots, but those went in the other direction, too noisy, so then I took those off and put the stock pipes back on, again, back to my desire of wanting more sound, so the V&H Longshots went back on again, I could never find that sweet spot, it was either too quiet or too loud.
Totally baffled with the High RPM CLAIMS. silenthill Vulcan 900 43 05-08-2011 02:30 PM
Clutch problems! I'm truly baffled! Enginemedic73 Vulcan 1500 0 05-07-2011 10:54 PM
OEM Chrome 900 Custom Exhaust/ De-baffled Stage 1 CGCWO Bikes For Sale 9 08-27-2010 06:50 PM
De-baffled my baby Toymaker Vulcan 900 8 07-27-2009 06:31 PM
Need Advice: Big City Thunder Quiet Baffles vs Hard Kore Quiet Baffles Rigormortis879 Engine Work 1 07-23-2009 08:01 AM
