V&H Fuel Pack vs. Power Commander - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 01-09-2012, 05:06 PM Thread Starter
I am about to put an exhaust on and don't know if I should go fuel pak or PC. The pc website doesn't even pull up an 2009 vn900 to get programs for. The fuel pak can be adjusted at the pack. I have no idea which is better performancewise either. I am going with VH Slash Cut and KN filter in the stock airbox. Your help is appreciated.
Ppafb1 is offline
post #2 of 7 (permalink) Old 01-10-2012, 11:18 AM
diehard rider's Avatar
I have a Cobra FI2000R fuel processor and to me that no different than the fuel pack, it only allows you to curve the air and fuel mixture and I think its a pain in the ass to get it just right. now if you go with the pc witch is what I wish I would have done, you should be able to download a map from the their website for your setup but the map will not be specifically for your bike but will get you by. I would recommend you find a shop in your area that has a dyno machine that can build a map just for your bike and that where you'll get your best preformance out of your bike. It's not cheap to have it done, anywhere between $250-$350. A buddy has a 900C with V&H slash cuts, Hypercharger with the PC5 and had it dyno'd and his 9 just walked away from me on my 9. Good Luck!
2012 GREEN/BLACK VAQUERO
Kawi Quick release backrest
Kawi Passanger floorboards
Kawi Luggage rack
Klockwerks 9" windshield
Mustang Seat
Mustang pass backrest pad
Ipod adapter kit/Ipod
Black ISO Grip
Offset ISO highway pegs
PC5 W/ignition
Freedom Performance True Dual Exhaust
Altrimax HP 195/55/16 car tire.
Leather saddlebag chaps
Thunder mfg Tornado air intake
Thunder mfg Throttle Body Gasket
diehard rider is offline
post #3 of 7 (permalink) Old 01-11-2012, 11:20 PM
V Twin's Avatar
Both the Fuelpak and Power Commander allow you to add and remove fuel so they pretty much can be configure to do the same job. The only big difference is PC has more available maps available to download. Don't worry about the year, select a earlier model and you'll get the maps.
Gitty Up & Go!
V Twin is offline
post #4 of 7 (permalink) Old 01-12-2012, 06:34 PM
KenDawg's Avatar
Color: Blue/White
I have the Cobra Fi2000R PowerPro fuel processor and my bike always runs perfectly with very, very little popping. It adjusts fuel/air mixture based on readings taken 80 times per second. Theres no need to dyno, worry about maps, or make on the fly adjustments. It is truly plug and ride. Want to change pipes, it adjusts automatically. Air cleaner, it adjusts, change in altitude, it adjusts. The only drawback is cost ($489.95 at Phat Performance). Still, it's less than paying for the Powercommander and having a custom map made, or purchasing the autotune function with O2 sensor. Good luck with your choice.
KenDawg
1SG, USA (Retired)
KenDawg is offline
post #5 of 7 (permalink) Old 01-15-2012, 07:01 AM
whiting57's Avatar
plus 1 on the FI2000 Power pro.
whiting57 is offline
post #6 of 7 (permalink) Old 01-15-2012, 10:17 AM
Has anyone seen an independent test done on the PowerPro? I was hoping by now one of the biker mags would have done a before and after, even if it isn't on a Vulcan. I'm interested in seeing some hard figures 'cause one of these days the PCIII I have on one of my other bikes will fail and I'd like to give the new technology a try.
Sojourner is offline
post #7 of 7 (permalink) Old 01-15-2012, 02:10 PM
whiting57's Avatar
I got mine on to late in the season for a dyno run plus I'm still breaking the motor in. I can say for sure, the bike runs smoother and pulls a lot harder. As far as HP goes, i have no idea, i run just the Hypercharger with stock pupes, noise is not my thing. I will put it on the dyno in the summer after its 1st service.
Power Commander V fuel tuning vs ignition tuning Jchristian1094 Vulcan 1700 5 01-24-2017 09:11 PM
Radial vs. Bias, Metzeler 880 vs. 888 vs MC Commander II TrentonC Vulcan 2000 36 04-12-2016 01:01 PM
Fuel Management Opinion...Cobra vs. Power Commander 907Vulcan Vulcan 900 12 04-22-2013 12:36 PM
Do I need a fuel pack with just vance & hines exhaust chitown New Member Introductions 4 02-18-2013 10:01 AM
Power commander vs Fi2000 Power Pro Tuner weber81 Engine Work 39 11-27-2012 03:27 PM
