turn signal wiring help - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 8 (permalink) Old 12-19-2011, 06:50 PM Thread Starter
snowman's Avatar
Hey guys, need a little help wiring up the new front turn signals for my 900 classic. The ones I purchased are 12v dual filament with 2 wires (red & black) and the bike's wiring harness has 3 wires.
I've spent the last hour searching the forum and can't find anything how to wire these new turn signals. Any help would be greatly be appreciated.
Thanks and Happy Holidays,
Snowman
snowman is offline
post #2 of 8 (permalink) Old 12-19-2011, 08:37 PM
DESERT ANGEL's Avatar
I asume the red wire is for the signal filiment and the black is for the running light filiment, you can touch / connect one wire at a time to determine what' what, but before you do anything make sure the turn signal housing is grounded good posibly by the 3rd wire that you mention or the circuit will try grounding it self by the power wire good luck
DESERT ANGEL is offline
post #3 of 8 (permalink) Old 12-19-2011, 09:24 PM
bigsarge2012's Avatar
black is normally ground? If it only has two wires then its probaly single filament, look at the actually bulb is there two? If there is it may be a self grounding unit, thats how the kurys ones are,
bigsarge2012 is offline
post #4 of 8 (permalink) Old 12-20-2011, 06:44 AM Thread Starter
snowman's Avatar
Thanks guys, I will give it a try during the holidays.
snowman is offline
post #5 of 8 (permalink) Old 12-20-2011, 07:40 AM
What did you buy? Can you give us the catalog number?
Sojourner is offline
post #6 of 8 (permalink) Old 12-22-2011, 01:47 PM Thread Starter
snowman's Avatar
Sojourner,
They are Emgo, model #61-73190, smooth bullets.
snowman is offline
post #7 of 8 (permalink) Old 12-22-2011, 09:53 PM
Sojourner,
The websites that advertise the Emgo don't really come out and say if it's a dual filament or single. They do say it's incandescent, not LED. I'd pop the amber cover off and remove the bulb. If there's a single pin on the bottom of the bulb you know it's single filament. Two pins would indicate dual with the red being one circuit and the black another with the case going to frame ground.
post #8 of 8 (permalink) Old 12-22-2011, 10:23 PM
They are double filament.
sfair is offline
Rear turn signal wiring help! darkarcher Vulcan 900 4 03-04-2015 10:34 AM
Help. Turn signal reminder wiring Sailor Bill Vulcan 900 18 07-06-2011 03:16 AM
Replacing Right Front turn signal and Left Rear turn signal qxinfinity Vulcan 750 0 11-03-2010 04:02 PM
Rear Turn Signal Wiring ? 97vn800 Vulcan 800 5 10-15-2009 01:26 PM
Rear Turn signal help after removing signal minder SCSteve Vulcan 900 5 09-23-2009 08:25 PM
