vn 900 snaping or arcing noise - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 12-16-2011, 09:26 AM Thread Starter
hey guys i own a 2011 vn 900 and lately there has been a noise coming from the front of the bike it sounds almost like an ignition coil arcing and when it does it the rpms drop it seems to do it more on idle any help would be appreciated
storms is offline
post #2 of 3 (permalink) Old 12-16-2011, 10:42 AM
Strompilot's Avatar
Remove the headlight from its nacelle and check to make sure you don't have some wires touching that shouldn't be. Also, check where the wire bundle enters the rear of the headlight nacelle and check for possible wearing through the wiring insulation causing a shorting against the nacelle. Inside you will find two 12V accessory power leads that aren't connected to anything. They should have spade connectors at the ends, with plastic or vinyl insulating covers to prevent shorting.
If you don't come up with anything there, go down to the lower front left of the bike. There you will find the voltage regulator. Remove the screws that hold the rock guard in place, then remove the unit itself. There is a plug that you can remove. It should be seated solidly. If it isn't, and it's loose, the poor connection there could cause the sound as you describe it. Vibration from both the engine and the road could be causing it to make sporadic connection. If that's it, when it loses the connection, it will cause the rpms to drop. Beyond that, take it to your dealer for warranty work as they have all the proper diagnostic instruments to track down the problem.
'09 650 VStrom
Strompilot is offline
post #3 of 3 (permalink) Old 12-16-2011, 12:02 PM Thread Starter
thanks i have been wondering about the voltage regulator and the dealership i bought it from is a joke after 20 km the front end fell off
storms is offline
VN 750 Frame with 2004 VN 900 motor cblack57 New Member Introductions 1 08-27-2018 09:23 AM
2006 vn 900 noise in trans blackvulcanguy Vulcan 900 12 02-04-2015 06:42 PM
Vn 900 valve train noise jimmy74 Vulcan 900 10 11-06-2013 03:59 PM
vn 1500 vs vn 1500 FI (fuel injection type) tepes the impaler General Vulcan Talk 6 08-15-2011 07:05 AM
Humming Noise from Vn 900 custom Clip4487 Vulcan 900 9 07-23-2010 05:05 PM
