What are these wires for? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 12 (permalink) Old 12-15-2011, 07:45 PM Thread Starter
kingnba6's Avatar
well i was looking at the battery to put it on the tender last night. and i found these wires. i have no clue what they are for. did i disconnect something and forgot? ive owned the bike since new with 0 miles and its a 06 classic.
VROC Number: 35103
kingnba6 is offline
post #2 of 12 (permalink) Old 12-15-2011, 10:29 PM
waynebob's Avatar
Check the owners manual, I think they are an accessory power source. White/blue positive, Black/Yellow negative. (at least on my 09) I was going to hook up my battery tender and there is no room on top of the battery, I was thinking of using these instead.
waynebob is offline
post #3 of 12 (permalink) Old 12-15-2011, 10:48 PM Thread Starter
kingnba6's Avatar
sweet thanks. ill be taking a voltmeter tomorrow to see if they are switched or not(constant power)
seems like a good place to attach heated gear too!
VROC Number: 35103
kingnba6 is offline
post #4 of 12 (permalink) Old 12-16-2011, 07:04 AM
My 2008 also has additional accessory power wires in the headlight bucket. If your 2006 does, it may be an easier spot to connect your heated gear. Good luck!
2008 Classic LT
GearDoctor is offline
post #5 of 12 (permalink) Old 12-16-2011, 07:14 AM
Strompilot's Avatar
Those are, indeed, accessory power leads. They are unswitched, meaning they are always "hot." I used the ones under the seat to hook up my CB radio. I just have to remember to turn the radio off when I get off the bike. On my wife's bike, I hooked up an aux. source for her IPod using the leads in the headlight housing. On both of ours, I hooked up the heated jacket controls direct to the battery itself so avoid frying any wires.
'09 650 VStrom
Strompilot is offline
post #6 of 12 (permalink) Old 12-16-2011, 08:40 AM Thread Starter
kingnba6's Avatar
ok so it is always hot. is it fused? if so what type of fuse
VROC Number: 35103
kingnba6 is offline
post #7 of 12 (permalink) Old 12-16-2011, 10:45 AM
Strompilot's Avatar
10 amp, I believe, if there is even a fuse in that line. Usually you have a fuse inline with whatever you are connecting to those accessory leads.
'09 650 VStrom
post #8 of 12 (permalink) Old 12-16-2011, 03:42 PM
SteveJB's Avatar
Displacement/CC's: 1700 cc
Color: Candy Cardinal Red
Not only are they fused, but they're voltage regulated. If you try to use your battery tender there, you'll be feeding power the wrong way to the regulator. I don't know what that would do, but it can't be good.
SteveJB is offline
post #9 of 12 (permalink) Old 12-16-2011, 03:45 PM Thread Starter
kingnba6's Avatar
wasnt planning to put anything there really. even if i do add some extra lights or something ill wire it up by myself
VROC Number: 35103
kingnba6 is offline
post #10 of 12 (permalink) Old 12-16-2011, 07:20 PM
2chains's Avatar
i use mine to power my heated gloves, works great!
black vn900 classic
2chains is offline
Anyone know what these pre-spliced wires are intended for? Backpack Jack Vulcan 650 S 7 08-07-2017 07:26 PM
What are these wires? phipps33 Vulcan 1500 4 02-24-2017 01:10 AM
Help identifying these wires? + turn signal connector Dcrockett05 Vulcan 900 4 04-01-2014 08:32 AM
What are these wires?? 08 vn900 deadvulcan Engine Work 6 01-05-2013 07:24 AM
What are these wires for ??? ItsMePaul Vulcan 2000 4 11-22-2010 01:36 PM
