Extending out the footpeg brackets - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 12-06-2011, 09:30 PM Thread Starter
I read somewhere that washers and longer bolts can be used to extend out the footpeg brackets. I am thinking about this to compensate for .5 inch of hypercharger sticking out more than OEM airfilter box. As my legs are short, reaching the rear break means pidgeon toeing... which is not very comfortable.
Has anyone done this? I am thinking about using .5 inches worth of washers... which would move the breaks and foot peg by .5 inch. I will likely do both sides to stay even.
Is it simple as just unbolting the two bolts on each side? Do i need to worry about any connector, cables, clutch rod etc?
Thanks in advance.
2010 vn900c se
Riding in foggy/rainy San Fransciso
Tiefighter is offline
post #2 of 4 (permalink) Old 12-07-2011, 10:16 PM
shaggman's Avatar
Thanks in advance.
It is as simple as removing the bolts, put spacers behind, and replace with longer bolts. Although, if you go too far you will need to space out the rear brake reservoir as well. I spaced mine out about an inch without having to worry about the reservoir.
2008 Vulcan 900 Classic with foot controls swapped off of a custom.
Mustang Daytripper, HardKrome sideburner exhaust, slammed down 2"-3" in the rear
shaggman is offline
post #3 of 4 (permalink) Old 12-08-2011, 09:12 PM Thread Starter
Thanks! Didn't think about adding washers to the brake reservoir.
2010 vn900c se
post #4 of 4 (permalink) Old 12-09-2011, 11:59 AM
bigsarge2012's Avatar
if the stock forwards are still to forward you can throw the floorboard set up from a classic on. Might be a good fit?
bigsarge2012 is offline
Purchase Footpeg Brackets (new set for 900 Classic) Biohazard Vulcan 900 1 10-01-2014 06:58 PM
Extending the rear shocks on a 92 Vulcan John500 Vulcan 1500 0 11-29-2013 07:30 AM
Extending wiring for big bars Jrock817 Vulcan 1500 4 03-21-2012 02:06 PM
Extending Luggage Rack bearpawh Vulcan 900 2 04-28-2011 10:42 AM
