Risers - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 11-23-2011, 11:39 AM Thread Starter
Risers
Can the Phat II risers be installed on a 2010, 900LT,will this involve rerouting cables.Can these be purchased without buying through Scootworks directly? thanks
salf is offline
post #2 of 4 (permalink) Old 11-24-2011, 01:38 PM
Kerry's Avatar
I have the Phat II risers on my 2010 LT and really like them. You may or may not have to fuss with routing of the clutch, brake, etc cables. It depends on how much slack your particular bike may have. I had to adjust my left side electrical, brake hose and clutch cable, but it wasn't a difficult job at all.
Forgot to mention that you can buy some Scootworks stuff, including risers, from Meancycles. The risers are found on this page.
2010 Vulcan 900 Classic LT
Kerry is offline
post #3 of 4 (permalink) Old 11-24-2011, 06:33 PM
AtlAggie's Avatar
Yes, they can be installed on a 900 LT.
Yes, as Kerry stated, they will usually require rerouting behind the triple tree. If you have more slack than usual, you may not need to reroute. But my dealer tried to get a way without rerouting, and it screwed up my interlock switch, which allows you to start the bike in gear if you have the clutch pulled in. For more than a year, I thought the bike would only start in neutral.
Finally, yes, you can purchase direct from Scootworks, or have your dealer order from them.
AtlAggie
2010 Vulcan Voyager 1700
2009 Vulcan 900 Classic LT (Traded after 18,500 Miles)
SCRC # 009067, VROC # 32735
Road Captain & 1st Officer, SCRC Chapter 09 - North Georgia
AtlAggie is offline
post #4 of 4 (permalink) Old 11-24-2011, 07:50 PM
I have the Phatriser II's that were recently installed on my 900 classic. The only cable they had to replace was the brake line. The rest were moved behind the triple trees. Good luck.
Trialawyer1 is offline
WTT: Barons Pull-back risers for stock 900 LT Risers crazyriderguy Wanted to buy or trade Items 0 03-18-2017 03:23 PM
1700 grip, seat, risers, 900 turn single bar, risers. mes882 Bike Parts, exhausts, etc. For Sale 6 07-03-2016 12:03 PM
Risers or no risers? Thriller E Vulcan 1600 14 08-12-2012 10:28 PM
Has anyone installed the Drag Specialties Risers? fergy Vulcan 1500 0 03-31-2009 04:04 PM
Risers crooksie Vulcan 900 4 02-09-2009 06:53 AM
