Output shaft/tool design.Where the hell oil coming from - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 11-11-2011, 02:16 PM Thread Starter
bikeman2011's Avatar
Send a message via Skype™ to bikeman2011
Thumbs up Output shaft/tool design.Where the hell oil coming from
Well !!, I took out the left side cover ( timing inspection plate) in order to do my valve adjustments) I discovered oil on the primary drive pulley cover.Well , oil seal .Ordered the seal.Now all set to change seal,when I removed the plate ,no oil on pulley and the oilseal area.The only thing I could infer is the oil is coming from the electrical wire housing.I cleaned up the area and washed the drive belt ( soap and water,soft brush).No sense in changing the seal.
As I was there I designed a tool to which fit into pulley slots so that the force of breaking the nut is transferred to pulley/shaft axle.
CAN ANYONE ADD TO THIS??
Picts liink
http://s1131.photobucket.com/albums/...ol%20design--/
bikeman2011 is offline
post #2 of 3 (permalink) Old 11-11-2011, 05:52 PM
SteveJB's Avatar
Displacement/CC's: 1700 cc
Color: Candy Cardinal Red
The shots you took don't show enough for me to be sure but this looked a lot like my pulley cover when I pulled it off. I had an O ring leaking after the shop did my valve clearance inspection. Oil was dripping slowly out of the drain hole on the left side of the rear cylinder. It was hard to spot because it leaks very slowly and follows joints in the engine/transmission cases. One of the joints it was following was the pulley cover to the transmission. Since that's not a sealed joint, the oil collected behind the cover. Did you check that drain area for oil?
SteveJB is offline
post #3 of 3 (permalink) Old 11-11-2011, 06:19 PM Thread Starter
No I did not.Good point.
Stator Output Specs and Higher Output Stator Biker Dash Vulcan 1700 5 07-16-2016 08:41 AM
Warranty Pulley/Output shaft sfair Vulcan 2000 11 05-18-2016 03:42 PM
output shaft/gear problems Sedonadon Vulcan 2000 22 03-18-2015 07:24 PM
transmission output shaft swap jpcottageville Vulcan 1500 1 03-20-2014 12:09 PM
1600 Output Shaft Bearing Leejay Vulcan 1600 7 07-26-2010 05:03 PM
