90/90r21 Avon - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 13 (permalink) Old 03-11-2011, 08:04 PM Thread Starter
addco's Avatar
90/90r21 Avon
Just wonndering if anyone else is running a 90/90r21 on their 900 Custom. I put mine on last night and it rubs. It rubbed really bad on where the plastic fender bolts to the metal bracket. I ground down the nut piece and it barely clears now but it still drags a little on the plastic fender. I have rode it about 40 miles and at slow speeds you can hear it.
Does anyone know how to modify the fender bracket to get it not to rub or any other tricks to fix it.
addco
09 900 Custom SE
230 rear
90 front
lowered 2"
Chrome factory pipes - debaffled
addco is offline
post #2 of 13 (permalink) Old 03-11-2011, 08:37 PM
Jace Bror's Avatar
I have a Classic so I can't go out and look at mine. But looking at the pics on Kawi site. Are you talking about the bolts inside or the bolts that attach to the forks?
If it is the bolts in the fender, I would get some metal to raise the fender up higher. Like a small piece of flat cut aluminum that would extend the fender attaching to the forks.
I know my drawing sucks. Hopefully that would work.
eLi
South of the Twin Cities.
Ride the river.
'07 900 Classic "turned LT"
Cobra Fi2000
Kury HyperCharger
Metzeler WhiteWalls
Speedo fixer in back (170)
Fuel Gauge resistor
'00 Vulcan 750 (SOLD)
'73 Honda CL350
Jace Bror is offline
post #3 of 13 (permalink) Old 03-11-2011, 09:36 PM Thread Starter
addco's Avatar
I like the idea. I am thinking something like that but actually cutting the bracket and adding a piece into it? Or maybe a whole different fender if there is anything custom out there that isn't crazy on price.
addco
09 900 Custom SE
230 rear
90 front
lowered 2"
addco is offline
post #4 of 13 (permalink) Old 03-11-2011, 09:50 PM
Jace Bror's Avatar
I don't mean to cut it. I wouldn't do that, cuz of resale value. I mean extend it so the fender sits higher. You could always run without a fender, custom chopper style. But then you might have to worry bout rocks getting kicked up and chipping the gas tank paint.
eLi
Ride the river.
Cobra Fi2000
Kury HyperCharger
Metzeler WhiteWalls
Fuel Gauge resistor
'73 Honda CL350
post #5 of 13 (permalink) Old 03-11-2011, 09:55 PM Thread Starter
addco's Avatar
The reason for thinking of cutting is it only needs to move up about 1/4". If I cut it and reweld it will be taken back to the point of looking factory. If it gets jacked up I will just order a new oem one. Just looking for any and all options, because I don't want to cut. Thanks for the ideas.
addco
09 900 Custom SE
230 rear
90 front
lowered 2"
addco is offline
post #6 of 13 (permalink) Old 03-12-2011, 03:38 AM
SteveJB's Avatar
Displacement/CC's: 1700 cc
Color: Candy Cardinal Red
I've been running a 90/90 Metzler on my custom. I've considered modifying the brackets by grinding out the holes were it mounts to the forks; making ovals out of them. I haven't actually taken the fender off to check out the possibilities. My Metzler doesn't actually touch the fender. Occasionally I get little gravel that zings through, but no rubber contact. Also, as the tire started to wear the issue went away. The Avon must have a different profile.
SteveJB is offline
post #7 of 13 (permalink) Old 03-12-2011, 08:24 AM
floridaboy's Avatar
I put a Metzler MH 90/21 frount tire on my Custom and the finder was real close on the frount to the tire. I took the finder off and used a rat tail file and elongated the frount holes to let the finder come up some for more clearance. I now have about 1/4 inch clearance on the top and 1/8 inch on each side of tire. After about 150 miles of rideing on alot of twisty roads i can not see any rub areas.
floridaboy is offline
post #8 of 13 (permalink) Old 03-12-2011, 09:38 AM Thread Starter
addco's Avatar
From what I am finding on other forums the avon has a different, more rounded shape and it doesn't work with out modification where the Metz does. Wished I would have found that info first. I have come up with a way I think to make it work, I will tell you what it is if it works. But thanks for the info I have received so far.
addco
09 900 Custom SE
230 rear
90 front
lowered 2"
addco is offline
post #9 of 13 (permalink) Old 03-12-2011, 11:06 AM
gillisfire20's Avatar
Good luck with the mods. Some have just added in a home made bracket to move the fender up and change the heads on the mounting bolts to some thing with a lower profile. But ya, the Avon 90/90 requires mods, the 80/90 is a direct fit.
gillisfire20 is offline
post #10 of 13 (permalink) Old 03-20-2011, 07:55 PM Thread Starter
addco's Avatar
Took your advice and raised the fender. It's not perfect but it works doesn't look to bad.
ID:	4719   Click image for larger version
Name:	vulcan fender.jpg
addco
09 900 Custom SE
230 rear
90 front
lowered 2"
addco is offline
Vulcan 900 - AVON 230/50-16 rear and 90/90-21 front marvinsanremo Bike Parts, exhausts, etc. For Sale 6 09-23-2015 04:35 PM
VN900 Custom SE Avon 200/70 and 90/90 Installed Today sologeeks Vulcan 900 1 09-08-2013 09:50 AM
Avon Roadrider 90/90-21, New crazyj Bike Parts, exhausts, etc. For Sale 0 05-09-2012 04:38 PM
80/90-21 vs 90/90-21 ceb2216 Vulcan 900 8 07-19-2011 05:40 PM
90-90/21 Tire asheeler Vulcan 900 3 08-29-2010 05:10 PM
