Re: Installing V&H Staggerds - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 02-16-2011, 04:57 PM Thread Starter
I've got a set of Vance and Hines Slash Cut Staggerds to put on my 900 Custom and I may be all wrong on this but as I remember I heard somewhere there was an issue getting the pipes fully seated and torqued down into the heads as the V&H flanges were thinner than the stock ones. Thought maybe someone who has a set of these on their bike could tell me if they ran into this. Also can you get to the bolt that holds the baffles on each pipe in place without removing the Chrome sleeves over the mufflers once everything is assembled ? Pipes are not at my location right now so that's why I was asking. Thanks in advance for any help I can get with this. RIDE SAFE
BOBKAY is offline
post #2 of 3 (permalink) Old 02-16-2011, 05:15 PM
xcbullet's Avatar
Mine bolted right up with no problems. Tightened after a good run & a couple weeks later.
06 Vulcan 900 classic-Totaled
Vance & Hines staggered, PC3, K&N in stock opened up box, Darkside
Over & out
xcbullet is offline
post #3 of 3 (permalink) Old 02-16-2011, 06:03 PM
jagered's Avatar
yup... leave the bolts on the frame bracket lose and tighten the head bolts. then tighten the bracket bolts.
i think the guy that had my bike before me did it backwards because one head bolt looks bent.
And NO... you have to slide the sleeves out of the way. If you debaffle it, and don't like it being so loud... i have the hard kore baffles from smartpartz (http://www.smartpartz.com) ... my pipes were baffle-less when i bought it and didn't like it so i bought them. no use for them anymore because i chopped the exhaust!!!
'02 Drifter 1500
... just an awesome ride!
'08 Custom-ized
Candy Lime Green
jagered is offline
$^&(^&&^#$#& Turn Signals perrykw Vulcan 1700 7 06-09-2017 10:16 AM
Removing and Re-installing my front wheel KEWOOSKI Vulcan 900 2 08-04-2014 08:54 PM
Need to Re-Wrap Baffle V&H BIG SHOTS STAGGERED TonyBertram Vulcan 1600 11 12-04-2013 02:03 PM
To Re-Jet or Not to Re-Jet.....? Odin Vulcan 1500 13 12-19-2012 12:49 PM
V&H Staggerds without baffles ? BOBKAY Vulcan 900 3 06-02-2011 11:34 PM
