VN 900 Custom Tyre Pressures - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 02-10-2011, 08:24 AM Thread Starter
Andy-UK's Avatar
I got back on the bike last week after about 4 months off, the ride seemed a tad loose so I checked the tire pressures and they required a top up.
In looking into what the pressures should be set at, I came across many differing views, with some saying to crank them up to 40 psi.
The VN900C owner manual says:
F = 40psi, R = 28psi up to 97.5kg or R = 32 psi up to 180kg
What are your thoughts? I ended up sticking the rear up to about 40 psi (I don't way 180kg however lol, maybe about 90 or so.)
The ride does seem much improved but I want to make sure I am not putting myself at risk with over inflated tires?
Thanks,
Andrew.
'09 VN900 Custom SE
Heated Grips
Heated Jacket
Heated Gloves
National Cycle Hand Deflectors
kawasaki Cafe Windshield
Kawasaki Crash Bars
Highway Hawk Saddlebag Supports
Backrest & Rack
Garmin Zummo 660
Autocom
Wishlist
Scootworks Overdrive Pulleys - Front & Back
Baron Big Air Kit (BAK) Black Pinstripe
Flame Teardrop Mirrors with Sculptured Stems or
Arlen Ness Flamed Mirror
De-Chrome
Andy-UK is offline
post #2 of 9 (permalink) Old 02-10-2011, 09:13 AM
Jeep Pirate's Avatar
You are not at risk. The 28psi from Kawasaki is really to low. They put the pressure like that to make the ride a little softer since bikes don't have as much suspesion travel as cars. But the down side is lack of handling and also it kills the life of the tire. I have a Classic and I run both at 38-40psi. The first rear tire that I had needed to be replaced at 8000 miles per it had always been run at 28psi. Also, the Dunlop stock tire is not known for long life. But since I put Metzlers on and am running the pressures higher, it is looking like I will get about 20,000 miles on a tire. And the handling is definitely better too.
'07 VN900 Classic
Horsepower is an illusion.
Jeep Pirate is offline
post #3 of 9 (permalink) Old 02-10-2011, 09:27 AM
crossroads123's Avatar
I was run 40/40 in all my bikes.
crossroads123 is offline
post #4 of 9 (permalink) Old 02-10-2011, 09:28 AM Thread Starter
Andy-UK's Avatar
Thanks for that, was getting a little concerned lol.
I found the Dunlops needed replaced at 5000 on the rear, so ditched that and also had the Metzler put on, I have done about 6000 miles and the tire still looks good to run for quite a while longer, and thats after a trip through Spain in changing climate and terrain (Mountains, sea level, loose gravel and some dirt roads..... = interesting experience lol).
I'm now due to change the front (once the tire arrives from back order) and hopefully I'll have more confidence in the bike as the front is getting bald.
'09 VN900 Custom SE
Heated Grips
Heated Jacket
Heated Gloves
Kawasaki Crash Bars
Backrest & Rack
Garmin Zummo 660
Autocom
Wishlist
De-Chrome
Andy-UK is offline
post #5 of 9 (permalink) Old 02-11-2011, 07:29 AM
fysl's Avatar
i have a weird way for tire pressure i see the road print on the tire if the patch is 1/2 ( what i mean by patch is how much road dust covers the tire ) it's ok but if it's less that means the psi is over ??? thats my way and if it's over 3/4 of the tire that means the psi is low ???
-2011 nomad
fysl is offline
post #6 of 9 (permalink) Old 02-11-2011, 08:10 AM
bikeman2011's Avatar
Send a message via Skype™ to bikeman2011
My 2 cents.I go by tire manufacture specs.Also 2 factors to consider--weight and temperature.The colder it become there is volumetric contraction
bikeman2011 is offline
post #7 of 9 (permalink) Old 02-11-2011, 08:22 AM
pjd52's Avatar
I have an 07 900 Classic and have always run front and rear at 30-32 PSI. Just replaced the OEM Dunlops with Metzeler 880s at 14,000. Both front and rear still had life but the rear was starting to look like end of life so I made the change before putting the bike away for the winter.
pjd52 is offline
post #8 of 9 (permalink) Old 02-12-2011, 04:49 AM
Ghost's Avatar
I run 40 psi front and rear on my Custom.
Ghost is offline
post #9 of 9 (permalink) Old 02-15-2011, 06:30 AM Thread Starter
Andy-UK's Avatar
All answers greatly appreciated, thanks guys.
'09 VN900 Custom SE
Heated Grips
Heated Jacket
Heated Gloves
Kawasaki Crash Bars
Backrest & Rack
Garmin Zummo 660
Autocom
Wishlist
De-Chrome
Andy-UK is offline
Tyre pressures? RuaphuNZ Vulcan 2000 10 07-16-2014 12:58 AM
3 TYRE COMPARISION, well 2 tyre actually. greyhairhoon Vulcan 900 59 07-12-2014 06:12 AM
Tyre Pressures Keef General Vulcan Talk 1 05-29-2014 09:58 AM
Tyre pressures ENRICO Vulcan 900 18 12-26-2013 08:19 AM
tyre pressures ENRICO Vulcan 900 4 07-04-2012 08:11 AM
