So... Is it me, or is it the bike? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 19 (permalink) Old 10-16-2010, 04:22 PM Thread Starter
Is this bike light in the a$$ or is the the way I'm riding? 3 times in the last 2 days I've locked up the back brake. The first time we went into a full screeching lockup. Fortunately I stayed in line and rode it out without incident. The second and third times I could hear it starting to howl early and let off the brake early enough to keep from locking up full. Now maybe it's because this bike has a disk on the rear and my old bike had a drum brake on the back or maybe it's because this bike is about 180 lbs heaver. I don't know but I'd like to know if I'm alone here or have you all experienced also?
Thx,
RG
Ron_G is offline
post #2 of 19 (permalink) Old 10-16-2010, 05:13 PM
blakeh's Avatar
No it's a little light. I've seen my rear tire out of the corner of my eye a few times . Just ease off and she'll straighten out. Just don't lock up that front brake
2009 Vulcan Custom SE
Add ons:
Black Crash bar
Custom Black Passenger backrest
Black passenger floorboards
Switchblade Cafe Windshield
Mustang Touring Seat-----best money I ever spent!!!!
AVON VENOM 200 rear tire
Completely Debaffeled
My Bike :
blakeh is offline
post #3 of 19 (permalink) Old 10-16-2010, 09:20 PM
That's part of it. Mostly though I think it IS that there is a very effective rear brake on the bike. I've been on bikes that you have to really mash down the pedal for the brake to even start working. Not this bike.
Whenever you change bikes, you need to practice emergency stopping with them. They all act a little different and it could save your life or keep you from dropping a bike.
MrClean is offline
post #4 of 19 (permalink) Old 10-16-2010, 10:48 PM
ETC(SS)'s Avatar
That's probably the problem in a nutshell, although I've found the rear brake on the VN to be a bit on the spongy side. My other bike has Brembos- -and they're pretty effective! All depends on what you're used to. I usually just use the front brake (a bad habit, I know...) unless I'm in a bind - no pun intended. The Vulcan isn't really "light" ANYWHERE, although the "C" model is reportedly easy to lock up in the front with that skinny tire, not my observation - something I've been told. I have a "D" model. I've leaned into the brakes pretty hard several times in my brief career as a Vulcaneer, and I've found this bike to be pretty forgiving in simulated panic stops. I know....adrenalin will probably change that!
VERY good advise!! After I got finished with my MSF course, I took my (first) bike back to the venue and re-practiced all the stuff I learned - except the tight turn-in-a-box stuff (V-Rods turn like a toad!) This has saved my bacon TWICE so far with panic stops!
"Those who beat their swords into plowshares will plow for those who do not."
ETC(SS) is offline
post #5 of 19 (permalink) Old 10-17-2010, 05:52 AM
The front brake IS the brake of choice when above 10-15 MPH. Whenever your speed is such that you are NOT turning the handlebars to steer then use the front brake with a trailing rear brake. In a parking lot situation drag on the rear brake only (no front brake) while turning, or you'll dump the bike.
Sojourner is offline
post #6 of 19 (permalink) Old 10-17-2010, 07:52 AM
seandh07's Avatar
actually the fron is pretty composes when mashing the front lever. ive had the front squeezed all the way and no lock-up (and thats with the stock dunlops) .. yes its a custom .. i mean sure if you just yank it itll lock up but slow steady pressur and shell do fine. gotten my bike to stop from 60mph if 46 yards
Seandh07
SGT USMC
seandh07 is offline
post #7 of 19 (permalink) Old 10-17-2010, 08:40 AM
I had a VN750 before with drum brakes for the rear. Once i got the VN900 the braking was a different experience. Very sharp and gives me much more confidence.
krravi is offline
post #8 of 19 (permalink) Old 10-17-2010, 10:34 AM
MINI NSX's Avatar
I hardly use the back brake. The front has much more stopping power than the rear. The only time I don't touch the front is in gravels.
'09 Vulcan 900 Custom
'08 Concours 14
'05 CBR1000RR Repsol
MINI NSX is offline
post #9 of 19 (permalink) Old 10-17-2010, 12:02 PM
cruiser331's Avatar
Send a message via Yahoo to cruiser331
Originally Posted by MINI NSX View Post
I hardly use the back brake. The front has much more stopping power than the rear. The only time I don't touch the front is in gravel.
Man I'll tell you what I always use both brakes front and rear. In doing this you are using 100% of your braking. Maybe you are not pushing the pedal or squeezing the lever to achieve 100% braking but you have the potential to. The maximum you can achieve in the front is 70-75%. I have only locked up the rear brakes twice on mine so maybe I am not mashing it as hard but having come from bikes that had rear drums both my rear disk brake bikes stop so much faster and safer.
Bottom line is you will not stop as quick or as safe as you would if you are using both front and rear brakes. Even before taking my safety course I never considered using only one brake.
Agreed, in loose gravel I am light on the front brake especially at parking lot speeds. I do try to avoid loose gravel and dirt at all costs.
2008 Vulcan 900 Classic LT hued in Luminous Polaris Blue and Atomic Silver ~ named T'Pol ~
Having left space dock for another home planet, a 94 Vulcan 750, named Surak, Wine and Black Cherry
Recently added a sweet 2008 Nomad to my Vulcan galaxy, she is RED and BLACK named T'mere
cruiser331 is offline
post #10 of 19 (permalink) Old 10-17-2010, 11:41 PM
whiting57's Avatar
[QUOTE=cruiser331;86488]
QUOTE]
I agree, after a 20 year break riding, i went back and did the riding course, i use to be a front brake user 99% of the time, after a few runs using both brakes, i reduced my braking distances by about 1/3rd. I have only locked the rear up once, during an emergency stop, pulling a 125lb trailer with 150lbs of gear in it, cut off by a car, i stopped in time but ended up with a "pucker" factor of 9.25.
whiting57 is offline
Hey everyone glad to be on the site ,I'm out of so cal so ride all year it's great ha Motorman j3 New Member Introductions 2 08-24-2018 05:42 PM
Star Rider is now on a Vulcan Vaquero - So far so good. INEBANA New Member Introductions 1 09-20-2017 09:07 AM
So what makes mustang seats so great?? jimmy77611 Vulcan 900 12 05-22-2011 04:22 PM
so so close chapa_fire Vulcan 500 4 09-22-2010 10:13 AM
Alright so I can't feel my fingers so what! MN-Rider General Vulcan Talk 14 04-20-2009 10:48 AM
