Belt Tension check? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 8 (permalink) Old 10-10-2010, 09:32 AM Thread Starter
Belt Tension check?
Hi guys,
just wondering if anyone has a service manual that says how to check the belt tension. The darn Owners Manual refers you to your dealer . What's wrong with that picture. As if I couldn't do that myself. So if anyone has the service manual, can you please let me know what is says, how and where to check etc.
Cheers
Chris
Versys Chris is offline
post #2 of 8 (permalink) Old 10-10-2010, 09:48 AM
KenDawg's Avatar
Color: Blue/White
Originally Posted by Versys Chris View Post
Hi guys,
Cheers
Chris
1. Jack the bike up
2. Using a belt tension tool, check tension just in front of the swingarm crosspipe. Apply 10 lbs upward pressure.
3. Measure the deflection in the belt cover window
4. Specified deflection is -1.5mm - 4 mm
KenDawg
1SG, USA (Retired)
KenDawg is offline
post #3 of 8 (permalink) Old 10-11-2010, 03:51 AM
Originally Posted by KenDawg View Post
1. Jack the bike up
Hi Chris,
"Belt tension tool" Thai style. Broom stick, scissors jack from my Ford, 10# barbell weight and a socket to place between the bottom of the belt and broom stick. You can do the math LOL.
Sojourner is offline
post #4 of 8 (permalink) Old 10-11-2010, 07:07 AM
ETC(SS)'s Avatar
I'd lean more towards the 4mm than the 1.5. IMHO, the belt is a little tight from the factory if you only get a 1.5mm deflection @ 10lbs.
Even Kawi's 300-dollar belt is cheaper to replace than the repairs you'll suffer if you run the belt overly tight....and (again JMHO) anything less than 4mm is a little snug for me.
Good Luck!
"Those who beat their swords into plowshares will plow for those who do not."
ETC(SS) is offline
post #5 of 8 (permalink) Old 10-13-2010, 04:25 PM Thread Starter
Originally Posted by Sojourner View Post
Hi Chris,
Hey, I like that idea. That is right up my alley.
post #6 of 8 (permalink) Old 10-13-2010, 04:31 PM Thread Starter
Good Luck!
I agree with you. I am worried that the factory setting is a little on the tight side.
I still don't quite understand why KenDawg said to jack up the bike . All the bikes I have had with chains said to put the bike on the side stand (neutral weight) and check tension then. I would think that if you "jack up" the bike, the swing arm will go into tension just from gravity and no valuable reading could be achieved. Can someone clarify this for me please.
Thanks Chris
post #7 of 8 (permalink) Old 10-13-2010, 07:17 PM
Kerry's Avatar
Thanks Chris
I have the service manual for 900 Classics for years 2006 to 2010. Page 2-27 says to jack up the bike to inspect the belt deflection. AFAICT, KenDawg gave an abbreviated version of the manual's procedure.
good riding
2010 Vulcan 900 Classic LT
Kerry is offline
post #8 of 8 (permalink) Old 10-13-2010, 07:53 PM Thread Starter
good riding
Thanks Kerry,
I guess they (Kawasaki) should know what they are doing. It is still puzzling me though.
Chris
Drive chain lube and tension check dennisbernal91z Vulcan 650 S 31 07-05-2018 11:09 PM
How do you check cam chain tension when they have extenders cruzin Vulcan 1500 0 05-06-2018 09:33 AM
Another Belt Tension Question for those that do it yourself Replay13 Vulcan 1700 2 04-14-2011 02:00 PM
Belt Tension Note Jeep Pirate Vulcan 900 9 07-21-2010 05:17 AM
Belt tension spec ? Mailman Vulcan 900 0 07-20-2009 04:38 PM
