hard start then fi light on at idle???? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 09-23-2010, 07:26 AM Thread Starter
cummins's Avatar
didnt want to start today fi light flashing
when finally running at stop lights the fi light would stay on unless i revved
any ideas? going to call dealer but i thought someone here would know something!! thanks in advance!
cummins is offline
post #2 of 10 (permalink) Old 09-23-2010, 08:10 AM
do you have the idle turn down low?
2010 Vulcan 900 Custom SE
Kawasaki Cafe' windshield
Kuryakyn front Axel Caps
Smokinnitro is offline
post #3 of 10 (permalink) Old 09-23-2010, 10:02 AM
whitestar's Avatar
I had a similar issue...had a weak almost dead battery. Problem gone once battery was charged overnight.
whitestar is offline
post #4 of 10 (permalink) Old 09-23-2010, 08:19 PM Thread Starter
cummins's Avatar
well thanks guys idle seems ok and batt starts right up when i said hard start it cranked fine just didn't want to fire up... brought to the dealer there keeping her overnight they hooked up to the computer for the fi light but no codes stored the service advisor saw the light on when he rode to the back but the light never came back on for the tech .... they are thinking possibly the power comander is crapping out???? any thoughts
hopefully they will find something and soon weather is great and i bought her 5 days ago!!!!!!!!!!
cummins is offline
post #5 of 10 (permalink) Old 09-24-2010, 04:20 AM
Always possible the PC is giving problems. Easiest thing to do is disconnect the PC and go back to OEM connections at the fuel injectors. Try it again.
Sojourner is offline
post #6 of 10 (permalink) Old 09-24-2010, 04:43 AM
jagered's Avatar
ditto with the PC... are they easy enough to disable without having to remove all the connections?
also on the battery... use a meter at idle and see if you are getting around 13-13.5v... if not your idle is too low. i had that problem and my idle still seems to be flakey and changes from ride to ride?!?!
'02 Drifter 1500
... just an awesome ride!
'08 Custom-ized
Candy Lime Green
jagered is offline
post #7 of 10 (permalink) Old 09-24-2010, 05:55 AM
The tank will either have to be lifted at the rear or taken off to get at the two connections to the fuel injectors. Once the PC connectors are removed from both the OEM injectors and the OEM plug-ins the original plug-ins can be reinstalled on the injectors. The rest of the wiring to the PC can be left alone until it's figured if the PC is causing the OP's problem.
post #8 of 10 (permalink) Old 09-24-2010, 06:00 AM
jagered's Avatar
gotchya... i put mine on without lifting the tank but did take the air cleaner off for easier access... tank would probably be less of a hassle if i need to get to them in the future!
'02 Drifter 1500
'08 Custom-ized
Candy Lime Green
jagered is offline
post #9 of 10 (permalink) Old 09-24-2010, 06:44 AM
Tank is no hassle, less then 5 minutes. Pull speedo unplug the fuel sensor and over flow, remove coil cover unplug fuel pump, unclip and remove fuel line, unbolt the back of the tank and lift. Reverse to put on, the tank is just barely harder to take off then the seat.
MrClean is offline
post #10 of 10 (permalink) Old 09-24-2010, 10:33 AM Thread Starter
cummins's Avatar
thanks guys and i will DEFINATELY 100% follow these to see for myself when i get back just got off phoe with dealer got code for secondairy throttle position sensor he adjusted and went for a test drive
i'll keep posting as they keep me posted
hopefully this is all the bugs i have to work out!!!
thaks again this forum is great!!!!
cummins is offline
Idle idle idle Derek Vulcan 800 9 04-23-2017 08:49 AM
no go....then go real fast..then no go mercman Vulcan 500 18 06-10-2016 08:08 PM
Rough idle then dies. Xc01t0nX Engine Work 2 08-12-2013 07:36 PM
Start, stall, start then run? cgw_niu Vulcan 1500 14 10-16-2011 08:21 PM
2007 Vulcan lifter knock at idle then stalls high rpm Laundry Vulcan 1600 0 08-04-2010 07:25 PM
