Marbling didn't work... - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 11 (permalink) Old 09-08-2010, 07:41 PM Thread Starter
jagered's Avatar
Vance & Hines on '08 Custom - stock baffle gone (previous owner removed) so i installed hard kore quiet baffles
ok... i read gadgets page and wondering if i should attempt the reed fix?!? i need to try replacing the gaskets on the exhaust 1st but here is my question:
After marbling, what does it mean if you still get loud big pops???
i mean... would an air leak at the gasket get enough air in there like without having the marble in the hose?? it's almost as loud and as consistent...
it is beginning to annoy the heck out of me because it makes the bike sound like it is running like crap... well it is on deceleration?!?! but power wise it is fine (that i can tell). i know peeps say a fuel manager is not necessary when the exhaust is only changed... but would it solve this problem?
'02 Drifter 1500
... just an awesome ride!
'08 Custom-ized
Candy Lime Green
jagered is offline
post #2 of 11 (permalink) Old 09-09-2010, 12:31 AM
Does the decel popping occur at zero throttle or when you're at 1-2% throttle? Does it occur during the entire RPM range during decel or just before the engine reached idle speed? Yes, a leaking exhaust gasket will allow enough air into the pipe to cause decel popping. Also, if there's a vacuum leak somewhere causing the engine to run a little lean, decel popping will also occur. Check your hoses and caps.
Sojourner is offline
post #3 of 11 (permalink) Old 09-09-2010, 06:12 AM
1945's Avatar
As noted an exhaust gasket or vacuum leak will increase the likelihood of popping. The stock exhaust muffled the event. Except when I get lazy, I have to tweak my Fi2000 after extreme temperature changes or the popping gets worse. Decel slowly and most of the popping goes away. Kaw is behind other bike makers in learning fuel management programming for open loop injected systems.
2007 Custom
1945 is offline
post #4 of 11 (permalink) Old 09-09-2010, 06:54 AM
If you didn't use new gaskets OR didn't torque them down correctly you will have leaks and you will have popping. Amazing how much suction occurs after the exhaust wave goes by.
MrClean is offline
post #5 of 11 (permalink) Old 09-09-2010, 10:43 AM
V Twin's Avatar
Marbeling won't completely iliminate the backfiring. I will only minimize it.
Gitty Up & Go!
V Twin is offline
post #6 of 11 (permalink) Old 09-09-2010, 12:44 PM
Just occurred to me, if you're having marbling problems with your backfire you should either increase or decrease your fiber intake.
I now return you to your previously running thread.
MrClean is offline
post #7 of 11 (permalink) Old 09-09-2010, 01:09 PM
Pretzel's Avatar
Good LORD! I just choked on my soda... "running" thread another funny?
LED Run/Turn/Brake
Vance and Hines Duals
Dobeck TFI
Vista throttle lock
Pretzel is offline
post #8 of 11 (permalink) Old 09-09-2010, 04:32 PM Thread Starter
jagered's Avatar
cool beans all... thanks!
the bike came with the V&H's on it... and to my surprise, I just checked the exhaust pipe bolts... ALMOST FINGER TIGHT?!?! geez... i could turn the wrench with my pinky?!?!
well i have new crush gaskets on order and will replace when they are in just to be sure. i know how gaskets can get "cut" so worse case is these are beyond fixing so hopefully new ones will resolve at least any leaks there.
i want to get the Fi2000R anyway because eventually i am putting a BAK on... but not until the funds become available!?!?
thanks for the input!
'02 Drifter 1500
'08 Custom-ized
Candy Lime Green
jagered is offline
post #9 of 11 (permalink) Old 09-09-2010, 05:08 PM
V Twin's Avatar
Nothing against the FI2000R but I upgraded from this to the PCIII and bike liked it better. Just my .02 cents
Gitty Up & Go!
V Twin is offline
post #10 of 11 (permalink) Old 09-09-2010, 07:31 PM Thread Starter
jagered's Avatar
yea i thought about that one... but want on-the-fly adjusting and the PCIII has to be remapped by the PC right? ... oh, and I don't have any working PC's anymore!
'02 Drifter 1500
'08 Custom-ized
Candy Lime Green
jagered is offline
Resistor fix didn't work denali1234 Vulcan 900 7 11-11-2017 06:20 PM
marbling question hog157 Vulcan 900 22 04-20-2011 10:44 AM
Fuel Leak and Marbling buzaggie Vulcan 1500 5 09-08-2009 08:29 PM
What is this "marbling" thing? Maury Engine Work 5 10-10-2008 02:40 PM
What is this "marbling" thing? Maury Vulcan 900 6 08-29-2008 05:09 PM
