Gman Bully Question - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 09-08-2010, 11:35 AM Thread Starter
Tang's Avatar
Gman Bully Question
I am getting a Gman Bully second hand and I was wondering where I should start for settings on the Bully controller.
Here is what I am working with:
- Screen punched and 4 holes drilled in baffle plate on stock exhaust
- Arlen Ness Big air kit
- Secondary throttle plates removed
Any insight is appreciated.
Thanks!
Tang is offline
post #2 of 4 (permalink) Old 09-08-2010, 09:11 PM
Stompers's Avatar
bully settings
Here's the link. Good Luck.
http://gmanindustries.com/pdf/kaw900...structions.pdf
2009 Classic 900 Candy Red
OEM W/Shield (23")
OEM Backrest
Mutazu Luggage Rack
Iron Rider rear luggage bag
Saddleman Rigid mount bags
Cobra passenger boards
Jardine highway bar
Kury Highway pegs
Kury lisc plate mount
Cobra Tachometer
Showchrome handlebar temp gauge
Showchrome rear master cylinder cover
Ram-mount GPS (Garmin)
Kury ISO grips with throttle boss
Kury Air Cleaner cover (Scoop)
Mustang Tank Bib
Cobra Lightbar
Stage II Exhaust Mod (4 holes)
Mustang Seat
Stompers is offline
post #3 of 4 (permalink) Old 09-09-2010, 06:23 AM
I have a BAK and gutted pipes and the Gman bulley. The pipes are what are holding back your bike. Currently I'm running stock setup with the trigger point between cruise and slight accel being a little higher BUT richness is set stock. I throw a little more than stock fuel at it under hard accel but haven't screwed with that setting for a while. SO the lights are green set to fast flash, amber set to fast flash and red set to 2-3. greenblue is I think 2-3 amberblue 3 and red 3-4 I think. I set it for Stage1 setup but bumped the trigger a bit to keep from going into midrange accel on slight throttle changes. It just saves a little gas, the listed setup worked fine.
MrClean is offline
post #4 of 4 (permalink) Old 09-09-2010, 02:44 PM Thread Starter
Tang's Avatar
Thanks for the advice MrClean. To tell the truth you were the one I was hoping to snag with this thread
Before I read this I put it on stage 2 and took her for a short spin. I felt a huge difference in power!
I will go tune it down to stage 1 and see how it feels. Plus it may help the longevity of my engine
Tang is offline
any one use gman bully fuel processor mes882 Vulcan 900 5 04-14-2014 12:29 PM
Gman-Gtank aux fuel tank Hound Dog Vulcan 1500 2 12-15-2013 12:39 PM
Vulcan 900 - G-Man Bully FI Controller Tang Bike Parts, exhausts, etc. For Sale 12 04-12-2012 03:48 PM
Gman bully and kn filter advice RoninSpecter Vulcan 2000 2 03-22-2012 02:21 PM
