Need Some Help with a 900 Custom Not Starting. - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 14 (permalink) Old 09-04-2010, 04:47 PM Thread Starter
BOTM Winner
November 2015
kanuck69's Avatar
Year/Make/Model: 2009, kaw, VN900. Classic.
Displacement/CC's: 900
Color: Red 35. Lol burgundy.
Question Need Some Help with a 900 Custom Not Starting.
Howdy all, like most I'm here cause of a problem. What I've got is my bro's 07 900 custom. It wouldn't start for him after a 45min ride. He had a fella jump it and it ran for a bit but poorly. Now I'm on the scene. I've got a Vulcan 750 & this is a whole new breed of beast to me. The battery was pretty dead so I'm charging it as we speak. The odd thing to me & I don't see any reference to this in the owners manual (like I thought I would) when you turn on the key it's making a clicking sound roughly one click a second. The odometer light is pulsating along with the click. The FI light is also included in this puzzle. Is this a known issue that someone can help me with? Thanks in advance. Kanuck69.
kanuck69 is offline
post #2 of 14 (permalink) Old 09-04-2010, 06:06 PM
Banned
Post deleted
Glockster is offline
post #3 of 14 (permalink) Old 09-04-2010, 06:16 PM
gillisfire20's Avatar
I have to agree with Glockster, so that make two old aircraft mechanic's. But really, sounds like a bad battery. Give it a charge and make sure you have a good connection at the terminals. Has the bike sat for awhile or is this something that just started happening?
gillisfire20 is offline
post #4 of 14 (permalink) Old 09-04-2010, 06:20 PM
Banned
Post deleted
post #5 of 14 (permalink) Old 09-04-2010, 07:37 PM Thread Starter
BOTM Winner
November 2015
kanuck69's Avatar
OK, Back from dinner & went to check things out. The connections were good but disconnected them & reconnected just for $#!ts & Giggles. The clicking & the FI light are gone. but she still won't start. I'm lost, this is such a different machine from what I'm use to. Does anyone know of an online repair guide?
kanuck69 is offline
post #6 of 14 (permalink) Old 09-04-2010, 07:38 PM Thread Starter
BOTM Winner
November 2015
kanuck69's Avatar
PS, it barely has 3000 miles on it.
kanuck69 is offline
post #7 of 14 (permalink) Old 09-04-2010, 08:50 PM
Banned
Post deleted
post #8 of 14 (permalink) Old 09-04-2010, 09:53 PM
Also an option if you have a volt meter, check the battery at rest and when trying to start. If you have a full charge and then Drop to low during cranking it could be a bad cell on the battery. And being fuel injected, you should hear it pressure up when key turned on.
post #9 of 14 (permalink) Old 09-04-2010, 10:04 PM
Pretzel's Avatar
The clicking with the key on is probably the fuel pump trying to pressurize? Only 3k miles for a 3 year old bike hints to me that it sits a lot, and probably without a battery tender? Run the battery down to a local shop for testing, sounds like a battery that won't carry voltage under load to me.
LED Run/Turn/Brake
Vance and Hines Duals
Dobeck TFI
Vista throttle lock
Pretzel is offline
post #10 of 14 (permalink) Old 09-04-2010, 10:09 PM
txmedic712's Avatar
Is the clicking noise when you hit the start switch and coming from the right side below the seat? If so, it's the magnetic switch and it does this because there is not enough CCA on he battery. If the battery holds a charge is it getting power? If not trace the wires and look at the stator and regulator.
dum vita est spes est - While there's life, there's hope
txmedic712 is offline
Bike not starting, need help DJones Vulcan 1600 4 06-17-2016 09:37 AM
Help with 2009 Vulcan not starting madeinsin Vulcan 900 14 09-25-2012 06:00 PM
Need some feedback on some exhausts yones12 Vulcan 800 9 05-20-2012 07:02 PM
Need help with 1993 vulcan 88 1500 not starting. not cranking. bigsteveo Vulcan 1500 32 03-04-2012 08:12 PM
Gotta Do some engine work and need some advice simonsq Engine Work 5 03-02-2012 03:13 PM
