LED Turn signal Questions... - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 09-03-2010, 09:21 AM Thread Starter
Tang's Avatar
I bought some SINGLE LED turn signals off of Ebay to replace my stock turn signals. When I installed them I got the 4 way flasher affect on the new LED rear signals. No matter if I hit the switch to go left or right the LED signals flash like 4 ways. I unplugged and removed the front signals.
I have gathered that LEDs run on less power than regular lights, but my questions are about diodes and resistors.
I know that
1. What size resistor (if any) do I need for a single LED?
2. What size diode (if any) do I need to use for a single LED?
I know that bradkline had used these same signals, so they should work. The difference may lie in that he may still have his stock turn signals in place?
bradkiline's Thread
Thanks.
Tang is offline
post #2 of 4 (permalink) Old 09-03-2010, 10:07 AM Thread Starter
Tang's Avatar
After talking to a co-worker; I think I will try hooking up the front turn signals (that I previously removed) and see if that corrects the issue. If it does I can test the resistance that the front signal provides and get a resistor of the same value.
I may also try doubling the resistor value to slow down the blinking rate to simulate a front and rear signal.
I will post back with my findings.
Tang is offline
post #3 of 4 (permalink) Old 09-03-2010, 11:30 AM
When you activate the turn signal it is sending the signal to the correct side of the bike however the signal is also crossing over the indicator lamp on your tank and feeding the LEDs on the other side of the bike too. The simple solution is making or buying load resistors that mimic the resistance of a normal filiment indicator lamp. Your flasher will work normally too.
Sojourner is offline
post #4 of 4 (permalink) Old 09-06-2010, 05:01 PM Thread Starter
Tang's Avatar
After trying a few different size resistors with no success I decided to take the signal bulb out of the assembly on the tank. This solved the issue I was having.
Thanks for all the info.
Tang is offline
LED rear turn signal conversion to run/turn/brake paul33x Vulcan 900 2 05-23-2017 08:26 AM
LED turn signal with LED license frame needs load equalizer ? evodog Vulcan 900 20 07-12-2012 07:20 AM
Replacing Right Front turn signal and Left Rear turn signal qxinfinity Vulcan 750 0 11-03-2010 04:02 PM
LED turn signal indicator pickandpray Vulcan 500 4 04-10-2010 09:06 PM
Rear Turn signal help after removing signal minder SCSteve Vulcan 900 5 09-23-2009 08:25 PM
