horn relay - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 08-29-2010, 12:47 AM Thread Starter
Cool horn relay
Hey out there. I just bought a stebel nautilus air horn with new relay. Where is the horn relay located on the 2009 vulcan 900 custom? Thanks in advance.
pcmikey (AKA RoadKill)
pcmikey is offline
post #2 of 10 (permalink) Old 08-29-2010, 02:29 AM
No relay. The power to your OEM horn is right off the horn button. Take the wires from your OEM horn and connect them to the coil of your new relay. Take a new wire directly from the + battery post, preferably fused, and connect to one side of the N.O. contact on your relay. From the other side of your N.O. contact take a wire to your new horn. The other side of your new horn goes to the frame or all the way back to the - battery post.
Sojourner is offline
post #3 of 10 (permalink) Old 08-29-2010, 04:30 AM
relay
I mounted my horn relay on my classic right under the tank on the right side. Don't have pictures but there was already a screw there that holds the wiring. As my bike is black it fits right in and isn't noticeable. I get teased of the sound of my stebel (old buick) but it sure gets attention.
2009 Black Classic
Mustang Seat w/Backrest
Cobra Standard Backrest with Luggage Rack
Smoke Slipstreamer Windshield
Lindby Multibar Engine Guards
Homemade Lowers
Wally World Running Lights
Stebel Air Horn
Vista Cruise Control
Scootworks Front OD Pulley
Stage 2 Debaffle Stock Pipes
170/80/15 Pirelli Rear Tire
Kury Run/Turn/Brake module
gmer140 is offline
post #4 of 10 (permalink) Old 08-29-2010, 02:55 PM Thread Starter
Thanks Sojourner. I appreciate the info.
Ride safe, Mike
pcmikey is offline
post #5 of 10 (permalink) Old 08-29-2010, 02:59 PM Thread Starter
Gmer140, I'll follow your lead. My bike is orange and so is the relay.
Thanks much, Mike
pcmikey is offline
post #6 of 10 (permalink) Old 08-29-2010, 03:47 PM
Rollingbones's Avatar
I assume that what you meant was to run the relay off the horn switch and the power to the horn itself via the relay to a more stable power souce, such as an add-on aux line...
Mark...Rollingbones
2011 Harley Road King FLHR
2008 Vulcan 900 Classic (Sold)
American Legion Riders Post 383
Patriot Guard Riders
Sacramento Metro Fire CERT
West Fair Oaks Neighborhood Watch
________________________________
Ride Long and Prosper!!!
Rollingbones is offline
post #7 of 10 (permalink) Old 08-29-2010, 09:16 PM
From other threads I've read on other forums, running the power lead directly from the battery is much better. My understanding is the Stebel horn draws a fair amount of current. Having it on it's own fused circuit is safer and more reliable. So that would be a yes to your post.
post #8 of 10 (permalink) Old 08-29-2010, 11:48 PM Thread Starter
Soj
You are right. I read the fine print on the seber nautilus box with a magnifying glass (jeweler's loupe actually). the thing draws 18 amps. I am installing a 20 amp auto type fuse. BTW the original horn bracket can be used with minor modifications. I am mounting it leftward to assure clearance, plus it looks better that way.
Thanks again for your help.
Mike
pcmikey is offline
post #9 of 10 (permalink) Old 08-30-2010, 05:04 AM
Soj
Mike
Cool. Can we see a pic once it's mounted? I need something louder than the OEM horn over here to get the attention of various farm animals that prefer the road over the fields as well as moped riders who think the only reason to have mirrors is to squeeze zits all day.
post #10 of 10 (permalink) Old 08-30-2010, 10:51 AM
Jeep Pirate's Avatar
I mounted a relay on the right hand side of the bike just under the gas tank. There is a screw holding a little wire bracket that helps keep the wires all neat as they go forward. This screw is attached to the frame itself. The big massive part of the frame where the pipe from under the tank mates with the part holding the steering stem. Anyway, I just bolted the relay to the same spot with the same bolt an then ran the horn wires to the bottom connections. I didn't even have to change or cut the original horn wires.
Another option is to hide it all in the headlight bucket. You could hide a small nuclear reactor inside that thing. That is where the relay for my driving lights is hidden.
'07 VN900 Classic
Horsepower is an illusion.
Jeep Pirate is offline
OEM Relay Kit same as LED Flasher Relay? Rise Vulcan 650 S 4 07-16-2018 11:39 PM
Why do I need a Relay for new horn? wallacem Vulcan 500 5 07-23-2012 09:16 PM
HELLLLLLLLLP! with horn relay kfolse107 Vulcan 500 5 05-17-2012 08:18 PM
Horn relay question truckie453 Vulcan 900 16 03-22-2012 02:16 PM
Horn Relay problem? Toddster Vulcan 900 2 06-30-2011 01:18 PM
