Vacuum hose: where does it go? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 8 (permalink) Old 08-16-2010, 12:07 PM Thread Starter
I'm in the process of putting on new pipes when low and behold, what appears to be a vacuum hose is just hanging there not connected to anything. I have looked everywhere and can't seem to find out where goes.
I have a 09 vulcan 900 custom se, the hose is in the area underneath the leading edge of the seat, behind the engine.
jeff2201 is offline
post #2 of 8 (permalink) Old 08-16-2010, 12:54 PM
bigsarge2012's Avatar
That is your drain hose, or fuel overflow . Its there to release pressure in case of expansion in your tank, its not supposed to connect to anything. It should smell like fuel.
bigsarge2012 is offline
post #3 of 8 (permalink) Old 08-16-2010, 01:10 PM Thread Starter
thanks sarge, I just talked to the mechanic up at the dealer and they told me the same thing. First bike, so some of it is a little new.
jeff2201 is offline
post #4 of 8 (permalink) Old 08-16-2010, 02:49 PM
Jeep Pirate's Avatar
Don't feel bad. This is a good honest question. It is always better to ask a question and know that there is nothing to worry about, than to not ask and hope there is nothing to worry about. Especially with bikes. Engine failure on a car can be expensive. Engine failure at the wrong time on a bike can be deadly.
'07 VN900 Classic
Horsepower is an illusion.
Jeep Pirate is offline
post #5 of 8 (permalink) Old 08-16-2010, 04:35 PM
Just wondering if anyone has had gas actually come from the above check valve drain hose?
otrp is offline
post #6 of 8 (permalink) Old 08-16-2010, 04:41 PM
KenDawg's Avatar
Color: Blue/White
I have. I filled up, then parked in the sun on a hot day. I found a small puddle of gas under the bike.
KenDawg is offline
post #7 of 8 (permalink) Old 08-16-2010, 06:14 PM
Jeep Pirates right, you should never hesitate to ask a question. Thats what this forum is for.
post #8 of 8 (permalink) Old 08-16-2010, 07:18 PM
Mine has leaked with full tank, half tank or almost empty tank.
KenDawg,
Dealer replaced the check valve under warranty supposedly with a newly designed one from Kawi. The new one is better, but still leaks.
Dealer has checked with Kawi and the tube is not supposed to be leaking gas at all, that's what the check valve is supposed to stop, the gas from coming out.
Purchased my bike in January and the first valve leaked gas even on cold winter days.
Going back to the dealer with this, I'll update accordingly.
otrp is offline
no go....then go real fast..then no go mercman Vulcan 500 18 06-10-2016 08:08 PM
Vacuum hose wise1 Vulcan 1600 2 08-11-2011 11:11 PM
Ugh, quick vacuum hose question off of air filter Mambo Dave Vulcan 800 68 03-16-2011 07:34 PM
Vacuum Hose on Kuryakyn Hypercharger ? Voodoo Engine Work 2 08-18-2009 07:55 PM
vacuum hose loneeagle15 Vulcan 1600 3 04-14-2009 09:18 AM
