How do I delete attachments? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 11 (permalink) Old 03-02-2013, 10:31 AM Thread Starter
gv550's Avatar
I made a post with .txt and .pdf attachments, and now would like to delete both because they have my address and phone number on them. I went to edit the post but don't see how to delete them.
Also, is there any way I can remove my personal information from this .pdf (that was sent to me) so I can re-attach it to my original post?
Garry
2009 Voyager ABS:
Sold at 679,465 kms
Improve handling, suspension and tire life
with Garry's Fork Brace.
gv550 is offline
post #2 of 11 (permalink) Old 03-02-2013, 10:50 AM
R-man's Avatar
I think if you are signed into the forum, and go to your original post it will give you a button at the bottom that says "edit". Once you click that, you should also then have an option that says something like "advanced edit". Click on that and you should be able to see your original post and change most anything you want to.
I'm not sure about editing a PDF file - I think that is pretty hard without special software. The only thing I would try with normal software would be to try and copy the text and paste it into MS Word, then edit if possible and repost as a Word document.
2004 Vulcan Classic 1500 - carbed
Grips, Freeway pegs, engine guard
Floorboards, Nomad rear seat,
Custom made luggage rack, Windshield & Lowers
Saddlebags, Passenger floorboards,
Passenger armrests
R-man is offline
post #3 of 11 (permalink) Old 03-02-2013, 11:05 AM
Color: Orange SE
Like the above poster said, click 'edit' then 'advanced' and down below you should see a 'manage attachments' button. When you click that button you'll see a menu to upload new attachments but you'll also see your existing one, along with a 'remove' button.
Because of your concerns I went ahead and deleted the attachment for you in case you didn't read this until later.
As far as PDF editing, you'll need something that will convert a PDF into a format you can use (like .docx for MS Word). Google around and you can find some, potentially with a free trial you can use. To actually edit a PDF you need Adobe Acrobat ($449!) or another PDF editing software which will likely be expensive, as licensing from Adobe isn't cheap (they charge a lot to license other software to edit PDF files). Usually the conversion is a better option.
Romans5.8 is offline
post #4 of 11 (permalink) Old 03-02-2013, 11:27 AM Thread Starter
gv550's Avatar
Thanks guys.
Garry
2009 Voyager ABS:
Sold at 679,465 kms
gv550 is offline
post #5 of 11 (permalink) Old 03-02-2013, 11:33 AM
Re: How do I delete attachments?
You could just take a screenshot of the document, manipulate it however you like, then post it as a picture.
There are also free programs you can get that will print anything into PDF so if you want to stick with that format, you can take and fix the screenshot then "print" it as a PDF and post it.
Graybush is offline
post #6 of 11 (permalink) Old 03-02-2013, 11:40 AM Thread Starter
gv550's Avatar
Thanks, I've asked the sender to delete my info and resend the pdf so I'll wait to see if they will. Easiest for me!
If not i'll try the advice from here.
Garry
2009 Voyager ABS:
Sold at 679,465 kms
gv550 is offline
post #7 of 11 (permalink) Old 03-04-2013, 08:44 AM Thread Starter
gv550's Avatar
The sender gave me a copy without my personal info, so I've re-attached it.
Thanks for the help.
Great forum!
Garry
2009 Voyager ABS:
Sold at 679,465 kms
gv550 is offline
post #8 of 11 (permalink) Old 03-04-2013, 05:30 PM
R-man's Avatar
Garry, you have a lot of kms on that bike - what have you had to do to keep it going besides regular maintenance ??
Passenger armrests
R-man is offline
post #9 of 11 (permalink) Old 03-04-2013, 05:57 PM Thread Starter
gv550's Avatar
All my bikes seem to get a lot of kms, not sure how that happens.
I'm quite fussy about maintaining the bike, a list of parts replaced is in the other thread. The key (IMO) to getting long service life from my bikes is to keep them mechanically stock, original parts, and follow the manufacturers recommended service.
Garry
2009 Voyager ABS:
Sold at 679,465 kms
gv550 is offline
post #10 of 11 (permalink) Old 03-05-2013, 10:03 PM
R-man's Avatar
Sounds like your process is working
Passenger armrests
R-man is offline
How do i delete one of my threads dcole1025 Contact your forum Moderators/Admins 9 03-08-2018 06:38 PM
iPhone picture attachments rotated roka General Vulcan Talk 7 03-18-2014 02:43 PM
For a lack of anyother way to do this, Delete me JoeM New Member Introductions 0 02-28-2013 09:05 AM
How do you delete pics from gallery IF1960 General Vulcan Talk 4 07-24-2009 06:21 AM
