'05 vulcan 1500 classicfi fuel pump - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 01-07-2012, 04:44 PM Thread Starter
Can anyone guide me to a web site to purchase a new, after market, fuel pump, for my "05 vulcan classicfi?
Vulcanrider53 is offline
post #2 of 9 (permalink) Old 01-08-2012, 12:30 PM
What is wrong with your pump?
Post back.
sfair is offline
post #3 of 9 (permalink) Old 01-08-2012, 01:19 PM
CRUISERDON's Avatar
Fuel pumps are very expensive and seldon go bad. I would advise checking the power from battery out through ALL fuses first.
CRUISER
DON RUSSELL
Aspire Machining
'97 VN1500 91 Cubes Of Custom CLASSIC
original owner
Vance & Hine 2to1
engine, forks, ignition & carb mod's
WebCam cam & rockers hard weld & grind
NEW TOP END, NO LOOKS ALL GO GO
Maxx intake manifold system & super G carb 44mm
CRUISERDON is offline
post #4 of 9 (permalink) Old 01-09-2012, 08:56 PM Thread Starter
Post back.
I was told by a Kawasaki mechanic, while having my motor checked as to why it was running hot, pinging and running too lean, that the pump was running at approx. 77% capacity and would likely only last another 10-15000 kms. I have a 16 day trip coming up in June and thought it would be smart to pack a spare one.
post #5 of 9 (permalink) Old 01-09-2012, 09:37 PM
If he actually performed a flow and pressure check and found it out of specs, then I would change the filter first. Kawasaki does not list the filter as a service part, but it can be changed out with an aftermarket unit. Much cheaper than the entire pump assembly.
sfair is offline
post #6 of 9 (permalink) Old 01-11-2012, 06:05 PM Thread Starter
I asked the Kawasaki dealer in town here only to be told the filter can not be change separate from the pump. Have I been told the wrong info, if so I'm back to asking for help as to a web site where I can purchase these after market filters. Thanks for your input thus far.
post #7 of 9 (permalink) Old 01-11-2012, 09:10 PM
He told you the correct info as far as Kawasaki is concerned. They do not supply the filter seperately; but what you can do is remove the pump assembly from the tank, remove the filter and take it in to you local auto supply place and match it up for physical and input/output sizes, ensure that it is designed for fuel injection, clamp it in position and you are ready to go.
Sorry, I do not have the replacement number at my place here, or I would give it to you.
sfair is offline
post #8 of 9 (permalink) Old 01-11-2012, 09:15 PM
As an add, if you decide to do this, post back when the assembly is out and I will give you a procedure to clean the pump.
sfair is offline
post #9 of 9 (permalink) Old 01-12-2012, 06:08 PM Thread Starter
Thanks for the info. I will surely try that, however, I will be waiting till the temperatures increase outside as I have the bike stored in an unheated shop.
vulcan 1500 fuel pump wanted paulcagefighter Bike Parts, exhausts, etc. For Sale 1 10-02-2013 07:44 AM
Valcun 1500 Drifter fuel pump Nevin Vulcan 1500 4 07-11-2013 10:36 PM
fuel pump 93 vulcan 1500 Boxer New Member Introductions 0 12-28-2012 09:41 PM
1997 vulcan classic 1500 fuel pump question vulcan1500ryder Vulcan 1500 26 09-04-2010 11:43 PM
changing the fuel pump on 2003 Meanstreak 1500 Noel Gallagher Vulcan 1600 0 02-27-2010 02:52 PM
