battery draw when starting - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By vulcandoc
post #1 of 10 (permalink) Old 08-11-2017, 11:34 AM Thread Starter
Looking for help with an ongoing issue with my 2008 Kawasaki Vulcan 900.
I purchased a battery from Battery Mart September of 2016. For some unforeseen reason, my batter has a slight drain. I have checked the stator; itís good, I have checked my voltage regulator/rectifier; it's good, and I have checked for parasitic draws and I found nothing
When the bike is running the system is charging, but when I start the bike there is such a draw that my clock resets.
Any ideas.
Mike
mmurrellm is offline
post #2 of 10 (permalink) Old 08-11-2017, 12:26 PM
JParton357's Avatar
Year/Make/Model: 2013 Kawasaki Vulcan Voyager
Color: White/Grey
It's a stretch, but if that many amps are getting cranked I wonder if the starter motor is having issues...?
2013 Vulcan Voyager
Traveled West to East
JParton357 is offline
post #3 of 10 (permalink) Old 08-11-2017, 12:32 PM Thread Starter
I will look into that, thanks.
Mike
post #4 of 10 (permalink) Old 08-11-2017, 01:06 PM
Post back with the charging voltages you are reading.
sfair is offline
post #5 of 10 (permalink) Old 08-15-2017, 08:33 AM Thread Starter
Battery voltage draw is 10 volts. I check for a parasitic and nothing. The battery is almost a year old I'm starting to think its the battery. Having it checked today after work.
Mike
post #6 of 10 (permalink) Old 08-15-2017, 09:16 AM
Are you saying that with engine running at fast idle, you get 10v?
sfair is offline
post #7 of 10 (permalink) Old 08-15-2017, 10:26 AM Thread Starter
with the engine running, I'm getting a 13.9 to 14.2 the 10 volts was from the starter
Mike
post #8 of 10 (permalink) Old 08-15-2017, 11:26 AM
Color: Black / grey
If your dropping to 10 volts when you try to start then the battery is no good.
Might have a starter problem, but load test that battery first.
trainermb likes this.
vulcandoc is offline
post #9 of 10 (permalink) Old 08-15-2017, 01:29 PM
Is clock reset the only issue?
Does it do it on every start?
sfair is offline
post #10 of 10 (permalink) Old 08-16-2017, 12:28 PM Thread Starter
Yes, the clock resets after attempting to start the bike several times, I believe that this is due to the draw on the battery. I had the battery tested and it came out at 84% and 12.92 volts which is good being that it had not been charged.
While I had the battery pulled and cleaning my terminals and connections I tested the starter and it was fine. I also checked the starter solenoid relay and noticed that it was quite pitted and corroded so I cleaned it up as well. I also ordered a new one costing only $7 bucks. Cheap fix, I can only assume that the contacts inside are twice as bad.
I also noticed that my air filter was dirty and my pre-filter was full of oil so I cleaned all that up as well.
This morning, I noticed that the bike turned over quite easily.
Iíll keep you informed after the new part comes in.
Mike
Battery draw, normal drain? andyvh1959 Vulcan 900 2 04-26-2017 05:57 PM
EOKO Current Draw dfen911 Vulcan 2000 10 03-22-2014 10:24 PM
Starter amp draw? Turbojoe Vulcan 500 9 08-28-2011 10:14 AM
Battery & Elec. Draw Gauge Helek_52 General Vulcan Talk 3 01-12-2011 07:27 AM
97 vulcan starting issues/battery? Turbo_Paul General Vulcan Talk 4 04-27-2010 11:26 PM
