Oil and coolant - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 03-05-2019, 10:12 PM Thread Starter
Throttle13's Avatar
Oil and coolant
I'm new to Kawasaki so I have a question or 2 . I have a 06 meanstreak 1600 and looking to see what everyone runs for oil and coolant. My honda vtx I ran rotella and worked great...any suggestions?
Thanks Brian
Throttle13 is offline
post #2 of 6 (permalink) Old 03-06-2019, 11:50 AM
Reptilicus's Avatar
Year/Make/Model: 2008 Mean Streak
Displacement/CC's: 1600
Color: Candy Fire Red
Since it gets changed fairly often I use regular non-synthetic; Valvoline 4 stroke motorcycle 10-40. So far so good. Haven't done the coolant yet but will try to get to it before riding season. I will probably use whatever the manual suggests.
Reptilicus is offline
post #3 of 6 (permalink) Old 03-06-2019, 01:26 PM
Hathaway's Avatar
Year/Make/Model: 2015 VN1700B
Color: GRY/BLK
Valvoline makes a good motorcycle oil. Kawasaki, Suzuki, Yamaha, and Honda sell good oil and antifreeze for motorcycles. I use Harley straight petroleum oil on my Harley, because it is air cooled, with a separate oil for the primary and transmission. I don't use synthetic on my bikes.
Hathaway is offline
post #4 of 6 (permalink) Old 03-06-2019, 01:47 PM
Sabre-t's Avatar
Color: Red/Black
Royal Purple Motorcycle (synthetic) 20W-50 in the summer due to Georgia heat and 10W-40 during the cooler months. I put enough miles on (most years) to do a spring and fall change sometimes twice or more for the summer months. Change at 4000 - 4500 miles.
I use O'Reily's yellow Universal (not the Dexcool compatible) 50/50 coolant. Change it every 2 years.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #5 of 6 (permalink) Old 03-06-2019, 02:45 PM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
for rad fluid you can go to nearest Honda car dealership and get a jug of Honda type 2 50/50 blue pre-mix, for oil any of the 15w40 diesel oils is good cause of the extra phosphate in it for bearings and gears protection and about synthetic oil if you do use that make sure you change it out at same mileage you would regular dino oil cause both will still become dirty regardless if it's synthetic or not
btom is offline
post #6 of 6 (permalink) Old 03-08-2019, 05:59 PM Thread Starter
Throttle13's Avatar
Thanks alot
Coolant in oil oldrockr Vulcan 800 2 07-12-2016 11:09 AM
Is this oil in my coolant? LeonardS Vulcan 650 S 2 05-13-2016 04:57 AM
Coolant checking and oil Jels Vulcan 500 12 04-06-2014 10:20 AM
Much needed maintenance... Plugs, coolant, oil, etc... atineo1982 Vulcan 900 8 03-27-2014 07:38 PM
What synthetic oil, and what coolant RoninSpecter General Vulcan Talk 15 04-03-2013 09:09 PM
