Oil Change - Kawasaki Vulcan 900 - Step-by-step Instructions - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
 4Likes
post #11 of 14 (permalink) Old 04-29-2019, 02:56 PM
Zzman's Avatar
Year/Make/Model: 2006 900 LT
Displacement/CC's: 900
Color: Blue and silver
Motor oil does both engine and trans.
2006 Vulcan 900 LT. Blue/Silver
Mods:
Partial Debaffle of exhaust
Crash bars
Custom grips
Passenger floor boards
Chrome radiator grill
Baron Big Air kit
Memphis Shades lowers
Michelin Commander II tires
Zzman is offline
post #12 of 14 (permalink) Old 04-30-2019, 10:14 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
Originally Posted by adeguerre View Post
found that a Honda/Nissan Oil Filter (cap type) wrench (64mmx14) fits the OEM oil filter perfectly
the NAPA Store has a 64.5mmx14 cap type wrench, will that fit their NAPA1358 oil filter?
btom is offline
post #13 of 14 (permalink) Old 04-30-2019, 10:18 AM
wolfy(TM)'s Avatar
Year/Make/Model: 2009 Vulcan Classic LT
Color: Red/Maroon & Silver/Gray
This is the way ALL tutorial videos should be.....audio was clear and very easily understood and the video was easy to watch because the lighting was spot on. Nice job!
wolfy(TM) is online now
post #14 of 14 (permalink) Old 07-30-2019, 05:50 PM
Originally Posted by liondog View Post
thanks yall
what about the 2012 v9 tranny oil, is it just the motor oil or separate?
If not, what tranny fluid, and how often should you change it, how?DIY.....?
Your oil also lubes your trans in your V900 so make sure whatever oil you used you use motorcycle oil with a MC-2 designation, it can be found on the rear of the oil container, this is to protect your clutch
Big Blue's Daddy
Barry Dupler is offline
Step by step coolant flush and change TS Tinker Vulcan 1700 64 03-22-2019 08:38 PM
Helmet lock installation step-by-step Děuris Vulcan 650 S 5 06-23-2018 02:54 PM
step by step rectifier relocation help Freydo Vulcan 1500 2 06-20-2013 06:22 PM
900 Hypercharger install instructions link here xxxxxxRTL Rider Vulcan 900 0 02-16-2012 06:33 PM
step by step oil change info for 2009 Vulcan classic lt. 3680 Vulcan 1700 4 08-22-2009 11:24 AM
