Pulled off front tire and fork stripped.. HELP! - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 8 (permalink) Old 06-20-2013, 10:00 PM Thread Starter
Just picked up my 07 Mean Streak on monday and it needed a new tire. After fighting the axle out, I now know why.
Is this repairable?
LWRDRMDNSS is offline
post #2 of 8 (permalink) Old 06-21-2013, 06:44 AM
reddyford's Avatar
No Pic!! Rim dinged??
reddyford is offline
post #3 of 8 (permalink) Old 06-21-2013, 08:55 AM
Administrator
MN-Rider's Avatar
Displacement/CC's: 1800
Color: Pearl White
You linked to another forum that requires you to log in to view anything.
Jeff, Twin Cities, MN
MN-Rider is offline
post #4 of 8 (permalink) Old 06-29-2013, 08:07 AM Thread Starter
No reddyford, only fork threads were messed up.
I'm sorryMN-rider, won't let me upload from my phone.
I was able to get a 24m x 1.5 tap and die and it torqued down to 79#.
Another question, should I use anti seize in axle? maintenance manual doesn't say to.
post #5 of 8 (permalink) Old 06-29-2013, 09:09 AM
Administrator
MN-Rider's Avatar
Color: Pearl White
Might consider hosting the pics with Picasa, imageshack, photobucket, etc and just link to them.
MN-Rider is offline
post #6 of 8 (permalink) Old 06-29-2013, 09:40 AM
reddyford's Avatar
I don't use anything but axle grease. I replace tires every other season, so seize up would never be in the equation. I use a 3/4" drive ratchet as long as my arm for the axles which makes loosening a piece of cake.
post #7 of 8 (permalink) Old 07-15-2013, 07:05 AM
whoaru99's Avatar
Generally speaking, I think it's best to follow the advice of the manual(s).
Using the wrong type or any lubricant where it's not really supposed to be changes the design properties of the joint/assembly.
whoaru99 is online now
post #8 of 8 (permalink) Old 07-15-2013, 07:07 AM Thread Starter
Thanks guys! Put it back dry.
Help!!! Clutch lever control stripped Pastork3v Vulcan 500 2 06-01-2017 06:32 AM
Sunuvagun, I pulled it off! Rhyno Wheels and Tires 0 05-16-2014 01:38 AM
need some help, stripped threads Captcoolhand Engine Work 8 04-11-2014 08:24 AM
stripped screw.. HELP!! pittdave Vulcan 1600 9 03-04-2013 07:34 AM
I pulled my gas tank and found this unplugged Angrywarvet Vulcan 2000 2 09-02-2012 05:13 PM
