Recommended tire pressure - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 06-14-2013, 02:52 PM Thread Starter
Whats the recommended (1 rider) tire pressure for a 1995 vulcan 1500? Front and rear? Factory sizes.
Thanks!
95vulcan1500 is offline
post #2 of 6 (permalink) Old 06-14-2013, 04:05 PM
Dean's Avatar
Year/Make/Model: 2006 Kawasaki Vulcan
Displacement/CC's: 1500FI
Color: Ebony Black/Galaxy Silver
On my bike I use Dunlp D404's sizes are
front, 130/90-16 rating 67H (speed and load) tire pressure 1 rider or 2 riders is 40lbs
rear, 150/80-16 rating 71H (again speed and weight) tire pressure is still 40lbs
This is what the book calls for. This is just FYI.
06 1500 Classic FI (Anniversary Edition)
Reward the truth, punish the liars...Ted Nugent
Dean is offline
post #3 of 6 (permalink) Old 06-14-2013, 04:06 PM
Dean's Avatar
Also new tires get new tubes and rim bands.
Dean is offline
post #4 of 6 (permalink) Old 06-14-2013, 04:25 PM
Color: Orange SE
You really need to kind of play with it to see what works for you. I wouldn't run below what the bike recommends (under the seat or in your manual) or above the sidewall pressure on the tire. Some run sidewall pressure as that may help the tires last a bit longer. Others stick to what 'the book' says. I run 38 front and rear on my bike. Works for me.
Romans5.8 is offline
post #5 of 6 (permalink) Old 06-17-2013, 05:20 PM
On a VN1500A with the 19" front wheel, the factory recommends 36 lbs front and 35 lbs rear or 40 lbs hiking...
sjvalleydave is offline
post #6 of 6 (permalink) Old 06-17-2013, 05:28 PM
Color: Orange SE
As an add;
Tire pressure may need to be adjusted for different conditions; just like suspension.
The tire pressure that works for you riding around town solo may not work as well two-up on the highway loaded down with luggage! I always raise my tire pressure a bit when the bike is loaded down, seems to help keep the bike feeling and handling the same in either scenario.
Thinking of Designing an Oil Pressure adapter for oil pressure and temp gauge bikeman2011 Vulcan 900 1 04-20-2011 05:01 PM
Recommended Tire Pressure Biohazzmat Vulcan 900 10 08-21-2010 08:48 PM
Recommended Tire Pump for a 1600? Martini Man Vulcan 1600 2 11-15-2009 04:03 PM
Recommended front/back motorcycle stands? lclark01 Vulcan 900 0 05-06-2009 11:32 AM
