Change brake pads now? - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By bearslayer
post #1 of 7 (permalink) Old 05-11-2019, 03:22 PM Thread Starter
Year/Make/Model: 2006 Kawasaki Vulcan EN500C
Displacement/CC's: 500
Hi all,
Never done brake pads before on a motorcycle and I'm not sure if it's time to change them or not. This is my first time really examining them closely on my EN500 LTD (I usually have to get it inspected every year but didn't this year). Looking at them now, I can see there's a decent amount of material left, but there's also a metal clip or bracket holding the pad onto the caliper that seems it will hit the rotor before the pad is completely worn. I'll try to post a picture but it's hard to see.
Image is blurry - hard to focus down into the slot - but I labeled it below.
Is this normal?
Lindog500 is offline
post #2 of 7 (permalink) Old 05-11-2019, 04:49 PM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
you better change out those pads for new ones
btom is offline
post #3 of 7 (permalink) Old 05-11-2019, 04:52 PM
btom's Avatar
whenever you have brake pad doubt, always always change them for new ones
btom is offline
post #4 of 7 (permalink) Old 05-11-2019, 06:44 PM
Tynker's Avatar
Year/Make/Model: 2009 Kawasaki Classic LT
Color: Green & Silver
That part of the metal clip will squeal when the pads reach their limit of use, time to replace when you hear it.
Tynker is offline
post #5 of 7 (permalink) Old 05-11-2019, 08:03 PM Thread Starter
I wondered if that was what it was -- so it won't damage the rotor? I haven't heard any squealing yet.
I'll order new ones and get ready to change them anyway, it just seems strange because it limits the amount of life the pad has by quite a bit.
post #6 of 7 (permalink) Old 05-13-2019, 04:46 PM
Year/Make/Model: 2015 Voyager
Color: Black/Gray
Most brake pads on motorcycles have a wear indicator on the lining of the pad. It looks like a "step", at the edge of the pad (some aftermarket don't). This is just before the pad wears down to the clip. If you look closely, you will see the pad, touching the rotor, and the step, leaves a slight gap. When you can't see the gap- the step is gone indicating the pads are worn. The clip will start to chirp, if you go much beyond that. I also will warn you the motorcycle brake pads don't look all that thick when they are new, so don't condemn worn pads too soon. I looked at your photo, and it looked like it still had wear left on it. You could always take it off, and inspect it completely. Of course, at that point, you may want to replace it anyway, since it's off! (Decisions, decisions)
Hathaway is offline
post #7 of 7 (permalink) Old 05-13-2019, 05:35 PM
bearslayer's Avatar
Year/Make/Model: 2004 Nomad , 1985 BMW K100 X2 , 1985 Intruder, 1998 Ducati Monster, 1972 CL350, 1948 Indian CZ125, 2
Displacement/CC's: 125 -1500
Color: Blue & Silver , Black , Gray , Maroon,black,
Change now and enjoy a riding season without worrying about your brakes
Ricksza likes this.
That which does not kill me tends to really piss me off.
bearslayer is online now
Tip of the Week 08-17 Tip #3 Brake Fluid Change (Maintenance, Safety) Wild Bill General Vulcan Talk 0 02-19-2017 05:53 PM
New brake pads, seem to be just right.. Dago Vulcan 500 0 06-24-2016 01:42 PM
Caliper with new brake pads will not fit over rotor Eddy Vulcan 500 8 05-21-2016 02:00 PM
Advice needed for front brake pads replacement Frenchy Vulcan 900 14 05-02-2013 10:57 AM
brake pads change tcrider Vulcan 900 13 11-08-2010 03:02 AM
