cupping - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 02-06-2019, 05:47 AM Thread Starter
cupping
What causes cupping in tires?
gwedwards1612 is offline
post #2 of 6 (permalink) Old 02-06-2019, 07:04 AM
CRU
CRU's Avatar
Displacement/CC's: 1600
Screwed up suspension, hard braking, and improper tire inflation are all causes. You can find a ton more info on google.
Here ya go.
2008 Mean Streak Candy Fire Red
Vance & Hines Big Shots Staggered exhaust
Dyno tuned Power Commander III & K&N air filter
Corbin Young Guns saddle/Kawi Fire & Steel "Touring" Double saddle
Mapam forward controls
Kuryakyn Constellation LED driving lights w/turn signals
Kuryakyn ISO grips w/stiletto end caps
Kawi OEM backrest
Kawi Fire & Steel windshield
Bad Ace Billet handlebar risers
Signal Dynamics BackOFF XP brake light module
Tourmaster Coaster tool bag
CRU is offline
post #3 of 6 (permalink) Old 02-21-2019, 05:33 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
cupping is caused by improper tire pressure
btom is offline
post #4 of 6 (permalink) Old 02-22-2019, 09:24 AM
Patrick's1500's Avatar
Year/Make/Model: 2004 VN 1500E7
Displacement/CC's: 1470
Color: green over white
If you are in North America, your cupping (also called spalling) will be more severe on the left side of your tire. Lean to the right or left when you're going in a straight line and you'll feel the buzzing of the tire on the pavement. On mine it;s always way more pronounced on the left side of the r tire than the right. In the UK it's the opposite. It just means the tires are doing their job. My bike a has always developed cupping on the front tire, starting somewhere around 4-5k miles and there is nothing wrong with the suspension or air pressure. it also won't hurt anything and your tire will wear completely out before the cupping becomes a safety issue. All 4 sets of tires I've put on this bike have done it. When you lean into a turn, the leading edge of your tread pattern its the pavement first and wears first. The reason the left side wears out faster than the right is because left turns are more than twice as long as right turns, generally. I saw one article from a guy who monitored such things and discovered that he put about 30-50%% more miles on the left side over the life of the tire than the right just with left turns. Riding style and air pressure can help mitigate cupping, but you won't stop it if you ride much. Avoid sudden turns or excessive front braking and it will make the tires last longer.
Patrick's1500 is offline
post #5 of 6 (permalink) Old 02-22-2019, 10:08 PM
DKC
Year/Make/Model: 2008 en500c
Displacement/CC's: 500
Color: Black
One bit to add to Patrick's explanation, and some further clarification. The reason the left side of the tire wears faster than the right isn't the left hand turns so much.
Take a good, close look at the road. There's a crown with the center being the high point. They do this to help the water run off the pavement. Because of this, even on a straight road, you're effectively leaning left in relation to the road.
The admin are proposing major changes to our forum. Please take a moment and look them over and cast your vote here:
DKC is offline
post #6 of 6 (permalink) Old 02-23-2019, 08:41 AM
It's been a subject of debate for a long time, but I'm not completely sold on the road crown argument But it could be a contributing factor. This guy doesnt thinks so.
Motorcycle Tire Wear
Others do, though, from what I've read.
The main thing is to understand it's normal on these heavy cruisers regardless of what causes it and it won't hurt anything.
By the way, where are you located?
Front tire cupping Shark88 Vulcan 2000 5 09-24-2014 08:56 PM
Vn900 Custom Tire deformation DnKiKe Vulcan 900 2 07-26-2014 11:46 AM
Almost got rid of the front tire cupping g1nomad Vulcan 2000 0 05-08-2011 05:13 PM
front tire cupping matt36567 Wheels and Tires 3 09-11-2010 04:06 AM
front tire cupping bensonbunch2005 Wheels and Tires 5 09-17-2009 08:42 AM
