Front wheel swap - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 05-31-2018, 02:23 AM Thread Starter
RedHorse's Avatar
Year/Make/Model: VN 1500 Classic
Displacement/CC's: 1500
Color: Black
Front wheel swap
I need to replace the front wheel on my '97 vn800 Classic after an accident. I have read somewhere that a vn1500 front wheel will fit, although I don't know if it is only certain years or models? I understand that the 1500 wheel rim is slightly wider, but I'm not using a fender so that's not an issue. The '97 800 Classic (B2) and the '97 1500 Classic (D2) share the same brake rotor, caliper and axle bolt (matching part numbers). The 1500 hub does have a speedometer drive, which I assume I can remove as I don't want to have to lace my 800 hub to the 1500 rim. If anyone has used a 1500 wheel without a problem or knows if it is an easy swap let me know. I'm having problems finding a decent 'used' 800 wheel, but there are quite a few 1500 wheels available and cheaper! Thanks in advance.
RedHorse is offline
post #2 of 2 (permalink) Old 06-01-2018, 10:11 AM Thread Starter
RedHorse's Avatar
Color: Black
So, nobody knows the answer to this. I am getting desperate. I need to order a wheel but don't want to buy a 1500 wheel if I am not able to fit it to my 800.
RedHorse is offline
Vn800a , vn800b front wheel swap vulcanised Vulcan 800 11 02-19-2018 03:46 AM
swap 21" vn800a front with 16" classic wheel fosland1 Wheels and Tires 6 02-26-2016 11:58 PM
front wheel swap sunnybob Vulcan 800 2 10-28-2013 12:55 AM
front wheel swap other models? VicFlo Vulcan 900 0 06-29-2011 08:28 PM
