Darkside problem - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 06-09-2017, 09:40 AM Thread Starter
Year/Make/Model: 2013 Kawasaki Vulcan Nomad 1700
Color: Titanium and Black
Darkside problem
Ok, so I decided to try a 205/60R-16 KUMHO ECSTA LX PLATINUM XL rear tire on my 13 Nomad 1700. I had it installed on Tuesday and rode home with no problems and liked the feel. I didn't ride Wednesday. When I wanted to ride on Thursday, it was completely flat. I pumped it up to 40 lbs. and when I got up today, it was flat again. Possibly I picked up a nail, but I don't know and don't think so. The shop says they had no problem getting the tire to fit the rim and I plan haul it back to let them check it out.
Has anyone had a problem installing a 205/60R-16 when it would not hold air? It seems I read a thread a while back about someone who had this problem, but I can't find the thread. Does anyone have a thought on this?
Ultimate Seat with Driver Backrest
Ivan's ECU flash 2
Freedom performance Slip on mufflers
Luverne Kawasaki Lowering Kit
Batwing fairing
Darkside 205/60/16 with Endeavor reversed trike
Huddleston is offline
post #2 of 4 (permalink) Old 06-09-2017, 12:33 PM
rick's Avatar
Bad/stuck valve stem possibly? Are you using balance beads in the tire, these sometimes will get stuck in the valve stem and it will leak.
2005 800 classic
2012 Voyager ABS
rick is offline
post #3 of 4 (permalink) Old 06-09-2017, 01:41 PM
Year/Make/Model: 2005 Classic
Displacement/CC's: 1600
Color: Metallic Majestic Red, I think
Just recently I read a suggestion "run a tube regardless of the rim" when running DS
I guess for this reason?
I like smoke and lightning.
ClassicJohn is offline
post #4 of 4 (permalink) Old 06-09-2017, 02:03 PM Thread Starter
Mystery solved
I apparently picked up a 2 inch self tapping screw on the interstate. The tire shop plugged it and said they fixed 3 others yesterday with the same screw! Go figure, in a 30 mile ride home I was so lucky. I just knew it had to be related to the tire being seated properly or the valve stem as Rick says.
Thanks guys for your thoughts.
Ivan's ECU flash 2
Batwing fairing
Fuel Tap Problem - Petcock Problem Brewster_440 Vulcan 800 0 04-11-2014 08:46 PM
Darkside problem DANAD Wheels and Tires 1 05-18-2012 07:50 PM
Stalling Problem? - Maybe you have a Cosmic Ray problem in your area myVoyager1700 Vulcan 1700 1 07-30-2010 02:29 PM
Overhearing Problem? Maybe No Problem at All? QJC Oil and Lubrication 4 10-26-2009 06:38 AM
900 going Darkside vulcan08 Vulcan 900 14 09-20-2009 05:17 PM
