Running tubeless with spoked wheels - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 04-10-2017, 09:35 PM Thread Starter
BOTSpring Winner 2017
Shores's Avatar
Year/Make/Model: 1995
Displacement/CC's: 800
Color: Gold
I just finished installing my wheels after sealing my spoke rims using 3M 5200 Marine Adhesive - Fast Cure (24 hrs.) and installing new Metzeler 888 WWW tire on my 2008 Yamaha Roadstar. But it will work with any wheels. Went well, took my time, not leaks so far. The standard 5200 takes a week to cure. The fast cure 5200 takes 1 hour to skin over and 24 hours to cure. (took mine about 48 hours). The 4200 isn't as permanent, but skins over in about 30 minutes. The 4000 UV is better for steel, but again, skins over in about 30 minutes. I wanted more time to work it, so I chose the 5200 fast cure. The 5200 is very thick and sticky. Make sure you open the tube all the way or you will get hand cramps. I took only one tube ($24) to do both wheels. Will check them throughout the week for pressure before I pull it down off the jacks this weekend. I had my rims trued first and they needed no adjustment so I did not use the paper dots on the nipple heads as some folks do figuring with 35K miles it is unlikely I will ever need to true them. Here's what I did.
Cleaned the inside of the rims and nipples with a wire wheel, wire brush, Dremel tool, dental pic and sand paper making sure I got all the rust spots and oxidization off. There wasn't much on my 2008 wheels.
Cleaned everything real good with acetone.
The valve stems I bought were 8.3mm as necessary, but the rubber gaskets had a thick flange on them so I cut the flange off one of them and reversed the gasket under the beveled washer to make a good seal.
Original
Modified
Made a hard plastic template for each wheel to contour tight with the inside of the rim. Made it about 1/8" above the tops of the nipples.
Started at the valve stem and sealed it entirely. Moving the caulk gun up and down as you go ensures a good sticky bond to all surfaces.
Then covered about 6 or 8 nipples real good then went back and filled in the space and then used the template to smooth it up to the last set of nipples. Then repeated for 6 or 8 more nipples.
Took about 45 minutes to carefully do each wheel and it did not skin over until after I was done. That's a good thing. Cleaned any messes off with acetone before it dried.
Shores is offline
post #2 of 2 (permalink) Old 05-26-2017, 07:33 PM
TK-421's Avatar
Year/Make/Model: 2008 Kawasaki Vulcan 900 Classic LT
Displacement/CC's: 903
Color: Red/Black
How about an update? Having any issues after a month? How many miles have you put on them? Does it seem to seal well enough that you'd do it on your next bike as well?
TK-421 is offline
Swapping VN900C wheels with VN900B spoked wheels BenjaminJ Wheels and Tires 7 06-16-2018 09:15 AM
Running tubeless with spokes wheels Shores Vulcan 800 4 05-07-2017 09:31 PM
Powdercoating Spoked wheels CycloneRider Wheels and Tires 2 05-05-2013 07:57 PM
Non spoked wheels Glasshouse Vulcan 1500 7 01-02-2011 07:11 PM
spoked wheels on long trips?? jgcable Vulcan 1500 2 11-23-2009 03:22 PM
