Innertube valve stem clarification - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 14 (permalink) Old 11-08-2015, 12:12 PM Thread Starter
Pagman's Avatar
Can anyone clarify the difference between tr87c and pv78 valve stems? I currently have the 90 degree angled stem (which I prefer), but don't ever remember choosing a model type. I'm about to replace my rear tire and tube, and have always bought the "angled" stem. I'm now noticing there are different models? I don't know how this has evaded me before. They both look identical on seller websites and there is no specific clarification regarding these two versions on line. Thanks.
1997 vn800A
2002 HD Dyna FXDX
Pagman is offline
post #2 of 14 (permalink) Old 11-08-2015, 01:13 PM
Hot Cruiser's Avatar
That's interesting. When I wanted to order a rear tube and tire I had a difficult time locating online the correctly sized tube with an angled valve stem and there was no notification of any spec other than it has a 90 degree angle. Do the sellers have any info about the different stem specs?
Hot Cruiser is offline
post #3 of 14 (permalink) Old 11-08-2015, 03:59 PM Thread Starter
Pagman's Avatar
I've been having that same problem too. However, I found that Bridgestone accommodates my need for the Vulcan's rear inner tube. If you link at the link provided, you'll notice the second and third image have different stem models.
Bridgestone Tire Tube - Motorcycle Superstore
1997 vn800A
2002 HD Dyna FXDX
Pagman is offline
post #4 of 14 (permalink) Old 11-08-2015, 04:22 PM Thread Starter
Pagman's Avatar
I found my answer, thanks to an eBay ad. Apparently, the pv78 types are a taller version of the angled stem. The tr87 appears to be standard, thus a sufficient size. Here is the diagram below:
1997 vn800A
2002 HD Dyna FXDX
Pagman is offline
post #5 of 14 (permalink) Old 11-08-2015, 08:44 PM
Pagman, I had trouble with the stem types too when replacing tires- ultimately relying just on what photos were available that matched the originals. If you are saying the TR87 stem (in the image) will work, it appears there's no threads and lockdown nuts on that stem, which I believe are needed. Are we on the same page?
Harley165 - Vulcan500 - Triumph865 - Vulcan900 - Vulcan1500 - All sold but I miss em!
redfish is offline
post #6 of 14 (permalink) Old 11-08-2015, 09:39 PM
pmassey31545's Avatar
Year/Make/Model: 2005 Vulcan 1500 Classic FI
Displacement/CC's: 1500
Color: Silver
Hmmmmm??? Both of these posts make me wonder how unbalanced this makes your tire. Or if added weight is necessary to balance your tire. I use beads so I guess they would offset the stem.
But getting to a straight stem sure is aggravating. An add on 90 would be cool. Gotta go see if I can find one.
Current Bike-
*2005 Vulcan 1500 Classic*
-Cobra Lowboy Shotguns
-Kury Hypercharger
-Kury ISO Grips
-Brakeaway Throttle Lock
-Mustang Gas Tank Bib
-Leatherlyke Cross Country Saddlebags
-PowerPro Fi2000 Fuel Management System
-Crash bar with Highway Pegs
-Progressive Rear Shocks
-Driver and Passenger Floorboards
-Kury Multi-color LED Lights
-Windshield w/Homemade Lowers
-Cup Holder (A must have)
Past Bike-
2002 Vulcan 750
pmassey31545 is offline
post #7 of 14 (permalink) Old 11-08-2015, 09:43 PM
Color: Silver
Well....that didn't take long. Might have to get a set. For $2.50. Worth a try.
2X 90 Degree Brass Air Tyre Extension Valve Motorcycle Car Truck Bicycle Scooter | eBay
Current Bike-
-Kury Hypercharger
-Kury ISO Grips
Past Bike-
2002 Vulcan 750
post #8 of 14 (permalink) Old 11-08-2015, 09:50 PM
Nice! Didn't know those were available.
redfish is offline
post #9 of 14 (permalink) Old 11-10-2015, 06:47 PM Thread Starter
Pagman's Avatar
I highly doubt there would be an issue of balance regarding types of valve stems. After all, they are made by reputable companies to be placed into tires. I currently have a 90 degree valve stem on my rear tire and never felt an imbalance. Also, I have a skull head valve cap on that. If your shop is balancing your tire (as they should), then keep in mind that your tire is returned to you already balanced. I just never knew there were options for different angled and straight stems.
1997 vn800A
2002 HD Dyna FXDX
Pagman is offline
post #10 of 14 (permalink) Old 03-02-2016, 03:32 PM
boy_welder2000's Avatar
Year/Make/Model: 2015 Kawasaki Vulcan 1700 Voyager
Color: Black/Gray
Hate to dig up an old thread, but I am now in the same boat. Going to replace my tires this spring and I would like to put a tube in the rear with a 90 degree valve stem. Not sure what to go with. I am going with a 170/80-15 tire.
2015 Vulcan 1700 Voyager
Ivan's ECU ~ Kuryakyn Long Horn Highway Pegs ~ Chucksters Risers ~ Grasshopper Backrest ~ Dual Horns ~ 34024-1330 Kickstand ~ Kawi Gel Front Seat
2008 Vulcan 900 Classic LT - Traded
2002 Honda CB250 Nighthawk - Sold after 15k miles
boy_welder2000 is offline
Clarification or advice on pipes Thekevincollins Vulcan 900 2 05-17-2016 06:50 PM
Should I Replace Innertube Also?? Chas63 Wheels and Tires 7 01-19-2013 07:04 PM
Clarification on a 180mm Rear Tire (Michelin Commander 2 and others) Nerdybiker Vulcan 1700 12 09-29-2012 07:41 PM
Replacing front valve stem nut1605 Vulcan 1700 10 12-28-2010 06:06 PM
Valve Stem leak Doublenikkel Vulcan 900 12 09-26-2010 04:01 PM
