Plus size rear tire - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 01-24-2015, 05:05 AM Thread Starter
chrisman889's Avatar
Plus size rear tire
I have a 2014 900 Classic LT and need a new rear tire after only 5,000 miles.
The OEM tire is size 180/70-15 and I'm wanting to know if I can go a little bigger on the width and height of the tire without changing the wheel or any modifications. It looks like there will be enough clearance to put a bigger tire on there. Any suggestions?
chrisman889 is offline
post #2 of 2 (permalink) Old 01-24-2015, 04:17 PM
You'll find out alot of folks go with the 200/70/15, they will fit with no problem, although for the extra $$$ your only getting 20mm, which is 3/4 of an inch,, some also swear by the 170/80/15 which is taller yet and apparently somehow wider although it should be 10mm narrower, check tire threads on the 900forum....ride on...
wally segap is offline
Tire upgrade same rim different size tire 230/60B15 BlackedOutVulcan Vulcan 900 0 08-03-2010 02:56 PM
Rear tire size Muhammad10809 Wheels and Tires 5 07-07-2010 10:10 AM
rear tire size ? large Vulcan 900 2 02-10-2009 07:51 PM
