Removing front wheel - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 10-20-2014, 09:36 AM Thread Starter
Spocks Ride's Avatar
When removing my front wheel the only way I could do it is if I removed the rotor. Is there another way?
I have a 2003 Vulcan 800B. The caliper wouldn't slip pass the rotor as it came up in the rim.
Spocks Ride is offline
post #2 of 9 (permalink) Old 10-22-2014, 02:33 PM
you had to remove the rotor from the wheel before the wheel would come out? I don't know if there's something goofy about the 800 but that doesn't sound right at all. I would expect your caliper to be at or behind the 12:00 position, so that the rotor would move forward with no interference. If it's forward of 12:00 for some reason, you might raise the front a little higher so the wheel/rotor could drop down a little and then forward and out.
Idahoser is offline
post #3 of 9 (permalink) Old 10-22-2014, 03:45 PM
cuyahoga's Avatar
It does slip past. At worst you have to force it a little but the caliper is softer and will not scratch the rim. First loosen the axle nut, then rotate the rim to it's most forgiving position - even the best ones have some runout. Before you begin caliper removal on any bike that is a tight squeeze first radius both the inner and outer rotor edges with medium grit sandpaper. You are only removing a millionth of an inch but it will make all the difference in the world.
cuyahoga is offline
post #4 of 9 (permalink) Old 10-22-2014, 03:55 PM Thread Starter
Not even close. Looked to be a 1/4 inch over lap of the rotor from the pads. I should of took some pictures before removing the rotor.
Thanks.
post #5 of 9 (permalink) Old 10-22-2014, 05:40 PM
rick's Avatar
Did you try compressing the caliper some, a little makes a big difference. I have an 05 800b, except for color changes, they were all the same after the 1st year or 2, then only sprocket and 1st & 2nd gear ratios changed, those may have only been the 800A's even. Its a tight fit but should come off and go back on with rotor in place.
2005 800 classic
2012 Voyager ABS
rick is offline
post #6 of 9 (permalink) Old 10-22-2014, 05:42 PM Thread Starter
Thanks. When it's time to assemble I'll see if I can install with caliper in place and rotor on wheel.
post #7 of 9 (permalink) Old 05-18-2015, 05:37 PM Thread Starter
All back together and I had to do it in reverse of how I removed it.
I'm sure I'm missing something but for the life of me I can't see how it could be done with the rotor on the wheel.
post #8 of 9 (permalink) Old 05-15-2019, 08:54 AM
fastpakr's Avatar
Found this thread when searching for the exact same issue on an '04 800 Classic (16" wheels). I was helping a friend change his front tire last night and had to bail out because I didn't have a good allen key socket for the rotor. As far as I can tell, there's no way whatsoever for the wheel to come out with the rotor on. The caliper can't lift far enough for the pads to clear the rotor before it's in contact with the wheel. First time I've seen this issue.
'99 Vulcan 500, 29k miles
fastpakr is offline
post #9 of 9 (permalink) Old 05-21-2019, 12:35 PM
fastpakr's Avatar
Had a chance last night to go back for the front wheel. The rotor does need to be loosened, but not entirely removed. IIRC, it was a 6mm allen key for those seven bolts. Back them out about three turns or so each and that will allow enough movement to get the caliper off the rotor and out of the way to drop the wheel.
fastpakr is offline
Removing and Re-installing my front wheel KEWOOSKI Vulcan 900 2 08-04-2014 08:54 PM
Removing Rear Wheel old Vulcan 500 8 01-02-2013 06:06 PM
Removing plugs WITHOUT removing fuel tank griffjo Vulcan 800 15 07-16-2011 04:08 AM
Removing rear wheel? len Vulcan 1700 9 03-12-2011 12:45 PM
Removing rear wheel t-bear Vulcan 1700 10 12-09-2010 09:24 AM
